07-04-2015, 10:33 AM | #1 |
Old Guys Rule
20
Rep 73
Best clear bra
I just purchased a 2015 X5 and want to have a clear bra installed. I've looked a what I believe to be the top four companies and have ruled out 3m. I can't find any studies or comparisons on the net. I would appreciate your input.
07-04-2015, 10:41 AM | #2 |
Rep 128
Why did you rule out 3M? 3M's known for their adhesive and should be the best. I've never had clear bra installed, but I have purchased the material (3M) and use it on my electronics like phones/tablets/laptop screens... I just cut it into the shape I need. Some companies market it as Invisible Shield and such, but it's actually just the clear bra material. Works very well. However, over time the clear material will get dirty and change color (yellow). On a white car it'll be noticeable after maybe half a year but on a dark-colored car it should be fine. This is just based on my experience using this material on my electronics over the past 5 years.
07-04-2015, 10:28 PM | #5 |
176
Rep 360
Drives: 1M; E90 M3 ZCP; M4 GTS
I have Xpel Ultimate on my 1M with 5,400 miles on it, and it is yellowing considerably. My installer has switched to Suntek, which is also self-healing. So far so good, but obviously not 4 yrs under my belt like on the 1M. It has great clarity like my Xpel had. 3M also has a Pro Series now that is supposed to be pretty solid as well.
-kskpsu
07-05-2015, 10:28 AM | #6 | |
116
Rep 381
07-05-2015, 02:19 PM | #7 |
176
Rep 360
Yes, intend to do it soon. I think companies pay out differently for warranty work (i.e. how they handle material and labor), but as long as you go back to your original installer, or have a good rapport with a shop, shouldn't be an issue.
-kskpsu
07-19-2015, 10:04 PM | #10 |
#dubspec
6332
Rep 5,201
Avery nano fusion. Had the entire front wrapped on my dad's mclaren 650s. Had little to no orange peel at all! Looks fantastic
LCI ///F80 M3 Individual Atlantis Metallic / Black Full / Carbon Cermics / 6MT
MPE / M Performance & Carbon package / KW v3 / 20" HRE R101LW / 20" HRE 527s / Michelin PSS / 20% tint / 3d Design / Streckenn splitters / OEM GTS hood / EAS Carbon seatbacks / Carbon RKP sideskirt / Bootmod3 / M Performance Tri color alcantara / AWE S Flow instagram: @ dubsesd |
07-20-2015, 06:50 PM | #11 |
Rep 500
Same here. In fact, the installer prefers it over X-Pel because it's easier to form without leaving stretch marks. More than two years later, it still looks like it did the first day.
07-26-2015, 09:04 AM | #13 |
Rep 762
Drives: '23 BMW i7 xdrive60
I've always used Xpel Ultimate on all my cars and they are great. Never had any problems with them.
08-09-2015, 05:15 PM | #16 |
176
Rep 360
Just an update for your film considerations. I had my installer work with Xpel on getting the yellowing film replaced. They pay out something paltry like $50 in labor for the hood /fenders/rear flares, so he wanted to do that first instead of adding in the complexity of the bumper at the same labor rate per sq. ft. Improved, but the net result makes my front bumper look like something is up with it. I know of another installer that cited how 3M handles warranty work markedly better on their pro-series, and they stopped carrying Xpel. Something to consider. All top tier films have strong warranties on the film itself, but I also want an installer to be compelled to install with the same care and precision as the original application if an issue arises, particularly since my job has me relocating from time-to-time, and it may not end up at the same shop where they would be more inclined to do so (e.g. customer service, better financial proposition given a higher margin install up front, etc.). In this case, it was initially done with an Xpel authorized installer when I lived in IL, and now an authorized installer in Minnesota is trying to rectify it.
Suntek all the way.
-kskpsu
