      07-12-2016, 12:19 PM   #155
Ryngo
Drives: 2016 F85 X5///M, DG
Originally Posted by Alan l.
Dinan exhaust installed! I had my shop install it as high up to the diffuser as possible without it hitting the heat shields. Love the way it looks now.
Untitled
I like that - I'm going to bring mine back and have them adjust it.
      07-12-2016, 01:44 PM   #156
Slayerkillhate
Ukraine
67
Drives: M8
Originally Posted by Alan l. View Post
Is that RKP diffusor?
      07-12-2016, 01:46 PM   #157
Alan l.
Alan l.'s Avatar
5438
Yes it is.
      07-12-2016, 04:25 PM   #158
YEEZ23
Drives: '18 M5 DG/AB
Sound change is mild as expected. Tone is deeper and different in a good way. Under 3K rpm it will be hard to notice it being any different than stock. After 3K its noticeable and sounds perfect all the way to red line. Zero drone
Great for those that want something with a little more volume without being over the top.
Alan
I completely agree with this. It's just a little something extra. If you really want your car to scream, go with a different exhaust. But I love the fact there is no drone at all. Seems stock when in comfort and just cruising around town.
I have the same setup on my car including the rear!
      07-24-2017, 05:13 PM   #159
F32_435
Drives: 2015 BMW 435i (M Performance)
Yes it is.
Alan do you have any videos of your exhaust? I tried to dm you with a few questions regarding your setup.
Look forward to hearing back!
Aman
Project BattleShip
(Instagram - F32_435)
      08-01-2017, 02:52 PM   #160
Jenner
///M
Jenner's Avatar
133
Drives: M8C/Taycan Turbo/Roadster 2.0
Ordered mine from Auto Talent yesterday along with the intake. Hopefully they are both shipping today.
Are you guys leaving the active sound on with the Dinan Exhaust or disabling it?
      07-24-2018, 01:50 PM   #161
doshawker
XPel Satin Wrap
Drives: 2017 BMW F85 X5 M
Too bad the Dinan exhaust is back ordered!! I've been waiting for over 7 weeks for mine and it is still not here!!
I may go with another brand...
      09-20-2019, 12:34 AM   #162
donut_boi
Drives: 2015 F85 X5M DGM
Untitled
Sorry to revive an old thread...I was wondering how did individuals go about with raising the Dinan exhaust tips...shorter exhaust hangers, lower mounting point for the exhaust hanger or something totally custom.
Thanks in advance
      09-20-2019, 11:33 AM   #163
iconoclast
Self-Deprecating Narcissist
iconoclast's Avatar
7266
I love the exhaust the but my only complaints with it are the tips are one size too small and they hang too low not filling out the rear diffuser. If there is a solution for this please share.
      10-10-2019, 12:13 AM   #164
donut_boi
So did a little bit of research and found shorter rubber exhaust hangers that I bought from Amazon that worked very well. Raised up the exhaust tips about 20mm without any of the exhaust components hitting the heat shield. It now sits very similar to Alan I. set up.
Overall, it reduced the gap and very happy with how the tips sit with the diffuser. Below is the amazon link to the hangers:
Autobahn88 Universal Exhaust Muffler Hanger Bushing, 2 Holes, 10mm (0.4") Hole Size, fits for Honda, Mazda, Subaru - Yellow https://www.amazon.com/dp/B01LOPWIM2..._MQRNDb99VF4JG
Exhaust was very easy, support the exhaust with a floor jack, remove the two bolts for the hanger mount and then replace the rubber hanger, install back the hanger mount with the two bolts and then repeat for the other side. Total time it took for me to replace the rubber hangers was 30 minutes.
Hope this helps iconoclast and for everyone else with Dinan exhaust.
baliano287.50
cncmastr1588.50
      10-11-2019, 02:47 PM   #165
daytonaviolet
OEM CSL Whore
daytonaviolet's Avatar
Philippines
1250
Drives: 2017 F85 X5M
can you post pictures of your exhaust with these hangers used
donut_boi997.50
      10-11-2019, 05:52 PM   #166
donut_boi
Here’s a quick picture, not the best because of the lighting...
2015 BMW X5 ///M | Donington Grey | Aragon Brown
MRF Engineering | RG Sport | BMW Performance | Dinan | KW | Vorsteiner | Zito | iND | BMW Parts Pros | Coby
2010 BMW 328i AT xDrive E91 Touring ///M Sport | Alpine White | Saddle Brown
Appreciate 4
Blewx5m128.00
TheVazha685.50
F85MTuNED1620.50
      10-11-2019, 06:53 PM   #167
Blewx5m
Drives: 2015 x5m
That looks great! Is that diffuser rw carbon or rkp?
donut_boi997.50
      10-11-2019, 08:12 PM   #168
donut_boi
Thank you!
RKP but in fiberglass and painted gloss black for more of a OE look
      10-24-2019, 10:47 PM   #169
khcwang
Drives: 2018 X5 M
I had mine installed 3 weeks ago. One side is sitting lower than the other side. Any idea how to adjust the height? Please share your experience with your shop. Thank you.
      10-24-2019, 11:07 PM   #170
khcwang
Drives: 2018 X5 M
I just bought the hangers from Amazon as you recommended. My diffuser is OEM and I hope they will look the same height like yours after replace them.
donut_boi997.50
      10-24-2019, 11:23 PM   #171
donut_boi
If one side sits lower than the other, you may have to loosen up the connecting clamps in order to level out both sides prior to tightening them again. If that doesn't help then check your rubber hangers, one or both may be worn out.
Not sure how it would look but I'm sure it will help raise the tips up. Post pics once you have the new hangers on
      11-01-2019, 05:09 PM   #172
khcwang
Drives: 2018 X5 M
I got the hangers from Amazon. The front nut is blocked by the factory hanger which I cannot figured out a way to loosen it.
I guess I will need to bring the car to a local shop and have the technician with proper tools to make the adjustment for me....
      11-12-2019, 08:50 AM   #173
cncmastr
cncmastr's Avatar
Drives: E30 M3 Cecotto, F85, G05, G07,
2018 X5 M  [0.00]
2020 M2 CS  [10.00]
2005 BMW X5 4.8is  [0.00]
2006 BMW M3  [10.00]
How many hangers? 4?
donut_boi997.50
      11-12-2019, 11:39 AM   #174
donut_boi
Total of 2 hangers
cncmastr1588.50
      04-25-2021, 10:41 PM   #175
MOTO
Turbo fever
MOTO's Avatar
Drives: 2024 M340i
Necropost...got my Dinan system on the way and I also ordered the exhaust valve controller (key fob activation).
Can't wait to get it on. I want the car a bit louder but to remain tame/civilized when need be for work.
Sounds like this Dinan setup was a good choice.
Other question - would one still see a solid increase in sound and performance doing a Dinan CAI and exhaust only setup? I don't want to Dinantronics tune the car at this point...
Thanks.
      04-26-2021, 07:02 AM   #176
Dinan_Engineering
Dinan_Engineering's Avatar
Drives: Any BMW
Thanks.
Performance increase in terms of raw power would be minimal for both items without tuning to take full advantage of them (CAI specifically). For all intents and purposes both would essentially be an aesthetic / sound modification.
An axleback exhaust in general offers little additional power. Where it does is typically at the very top end of the power band. However, that handful of HP on a car that is already 500+HP means you would never notice the minor difference. The intake has a bit more performance benefit by way of improved throttle response and efficiency but like the exhaust you would be hard pressed to tell a true power difference.
