      06-01-2015, 09:44 PM   #23
EastCoast335i , PM'ed.
PM for Everyday DEALS!!
      06-01-2015, 10:04 PM   #24
turboawd
1636
Drives: 2015 X5 35i
is this what would work on a 35i?
http://www.rgsportshop.com/index.php...product_id=709
also, what is exactly included? is there a display? how do you switch tunes?
      06-01-2015, 10:14 PM   #25
Yes, that would be it.
It will only include harness, tune box, manuals, zip ties, and alan wrench to open the box and adjust the dial.
There are no display.
To switch the tunes on RC Ultimate is by opening the box and change the dial, while BMS Stage 1, you need to use the sold separately BMS DATA USB Cable.
If you are talking about switching it on and off, there is always on mode.
The one that you can switch on/off, change map, etc, that would be the BMS JB4 Stage 2.
      06-01-2015, 11:56 PM   #26
EastCoast335i
EastCoast335i's Avatar
Drives: 2015 X5 | 2008 335i
I'm a bit confused, your website says the jb4 stage 2 is not compatible with the X5 DME. Is this incorrect?
Also does the jb4 stage2 require tapping wires in the DME with wire splicing, posi-taps, etc...?
Unlike RC or BMS stg1 which plug into the vehicle using OEM connectors.
      06-02-2015, 12:14 AM   #27
Yes, those info are copy paste from their website.
I am not sure about E70 DME, but it is compatible with F15 DME.
JB4 Stage 2 require a use of posi-tab to connect to the CAN BUS. But, they just released the new addition where you can use the OBD2 port where you can buy it separately or make it yourself.
It still used the OEM connectors for the Fuel Rail, TMAP, and MAP sensors.
      06-02-2015, 12:47 AM   #28
Tim2189
Russian in a Bimmer
Tim2189's Avatar
Drives: X5 M50i
Are we able to run the RaceChip Ultimate on a stock F16 X6? or Do I need upgraded intercooler and what not
2013 X6 - retired
2015 X6 - retired
2015 435GC - retired
2018 X5 40e - retired
2020 X5 M50i - Current
      06-02-2015, 05:18 AM   #29
Kzang
Kzang's Avatar
3239
Drives: 2015 X5 35i Msport SG
It looks like RC Ultimate would be the best tune as far as convenience and ease of use.
      06-02-2015, 12:35 PM   #30
Yes, you can run RaceChip Ultimate or BMS Stage 1 on a stock F15 X5 / F16 X6. No intercooler upgrade needed.
But, I do suggest to upgrade the chargepipe as it is known to break even under stock condition. It will also increase the throttle response, especially under hot condition where the plastic pipe become softer.
      06-02-2015, 01:24 PM   #31
Tim2189
Russian in a Bimmer
Tim2189's Avatar
Drives: X5 M50i
Gotcha, thanks for the feedback. Got some decisions to make once my F16 is here next week
2013 X6 - retired
2015 X6 - retired
      06-02-2015, 01:27 PM   #32
      07-31-2015, 10:36 AM   #33
Igor_M5
Igor_M5's Avatar
Drives: Many, BMW.
Some insight on which wires are the CAN wires? Before I go chopping up the entire harness lol
      07-31-2015, 11:22 AM   #34
Here is the CAN wires that you need to tap.
      07-31-2015, 11:24 AM   #35
Igor_M5
Igor_M5's Avatar
Drives: Many, BMW.
Oh shit, you just popped off the little covers that go over each plug? You know what I had to go through to remove the plugs from the firewall to see what weres were coming out from underneath? lol oh god. ok awesome thanks !
      07-31-2015, 11:26 PM   #36
Yes, BMW put a cover on them now. Mine is early built 2014 F15, so it was bare like that.
      11-06-2015, 11:25 PM   #37
Don Juan
Don Juan's Avatar
Drives: 2020 X7 40i, 2020 I3s Bev
Attachment 1254243
This is what i was looking for
Im returning my f10 lease that has the jb4 stage 2 and bms intake and seems i will be able to use both in my f15
Question: did you try using map5? Supposedly it autotunes with a higher psi based on current conditions.
Thanks
2023 I4 40 Msport White/red interior 19"Rims
2023 Ix 50 MSport Hraphite Gray.Oyster interios 22" Rims
Retired
2020 X7 MSport 40i
2020 I3s Bev
      11-06-2015, 11:35 PM   #38
Attachment 1254243
Thanks
Yea, but don't like it.
The map 2 is my liking.
