12-02-2016, 03:01 PM | #2971 | |
Rep 25
I try to read SVT with boxes checked and also unchecked is same error. I can not injected cafd because when i read SVT have error and i can not Left-Click on EMF any solution to can read svt? thanks |
12-02-2016, 03:02 PM | #2972 |
Rep 25
ok thanks again for answer
i will try to read ecu thanks again i try to inject cafd and for the end of code camming error Last edited by saxonel; 12-02-2016 at 03:10 PM.. |
12-04-2016, 11:25 AM | #2973 | |
Rep 96
Drives: 2010 335d, 2018 540d
12-05-2016, 01:26 PM | #2974 |
Rep 213
Coding issue
Trying to code 2016 X5 35i. I keep getting errors when I try to read svt or code the ecu for VO coding. I even tried to FDL code and kept errors. Maybe not the best pics...maybe my coding software too old? I have coded other vehicles with no issues. Please help...
12-05-2016, 09:55 PM | #2975 |
Rep 592
Coolmex, read the above threads. That answer lies within with pictures. Lol. You were supposed to read the ECU not SVT. Good luck my friend.
12-05-2016, 10:30 PM | #2976 | |
Rep 8,364
12-05-2016, 11:34 PM | #2977 |
Rep 213
12-05-2016, 11:43 PM | #2978 | ||
Rep 213
I guess that's the problem. |
12-09-2016, 05:06 PM | #2979 |
Rep 570
@shawnsheridan
Vehicle just came back from the dealership and everything gone...? Could you please send me link to the latest version via PM? Thanks |
12-09-2016, 07:16 PM | #2980 |
Rep 8,364
12-14-2016, 01:24 AM | #2981 |
Rep 11
Cannot get a connection via VIN using Win7 and E-Sys 3.28.1
Instructions say: 21) Wait a few minutes until the Laptop Windows wired network adapter icon shows a Connection with the yellow exclamation point over it. Is this valid for Win 7? I can click on my network icon in the task bar and when I plug in the ethernet cable to the PC I can see that it detects it, and then reports "Unidentified network, No network Access" for a brief second or so, and then disappears., but no yellow exclamation mark? |
12-14-2016, 06:43 AM | #2982 | |
Rep 40,733
12-14-2016, 01:23 PM | #2983 |
Rep 11
Assuming the attached is the Connection window (I just snipped from another post as dont have my laptop in front of me now)... Mine looks the same as this, except the Target window has all the model options as per the data directory..
12-14-2016, 01:42 PM | #2984 | |
Rep 8,364
You may not see it if you have wifi enabled. You can also right click system tray icon and bring up network and sharing center to check you have fallback ip (169.x.x.x). The reason image you posted has no targets is their psdzdata is either not installed or extracted incorrect. For proper connection: 1) Make sure motor is running if car is not on a Charger. 2) Make sure to disable third party antivirus and firewall programs (eg, Kaspersky) 3) Make sure LAN Adapter is set for DHCP and not using a Static IP. 4) The Target Connection Window should not be blank (It should show multiple target connections for different chassis') |
12-14-2016, 01:43 PM | #2985 |
Rep 40,733
Ok, if Target Window has models, then PSdZData install is good. It is most likely ENET Cable or Windows Networking issue.
12-14-2016, 10:58 PM | #2986 |
Rep 84
I was hoping someone could help me out with this.
I have a '17 x5 that I coded for the fob to close all sidemirrors and windows etc. For some reason when i press unlock, the side mirrors dont open back up again automatically. Is there a separate code for this?? On the F10 my friend has he needed no extra code :T |
12-15-2016, 01:19 AM | #2987 | |
Rep 11
As you can see the data files all appear to be there, and the wee yellow exclamation mark is there is well. I did have the engine running so battery voltage should be ok. Is there any networking settings I should be checking? I did use the cable and laptop previously with E-Sys v3.24.3 to successfully code this same vehicle, however after a recent service the dealer did a major software update on the vehicle and wiped my coding. When I tried to code using the 3.24.3 version I had the same problem, I couldnt connect via Vin so thought that maybe my old version was no longer compatible. |
12-15-2016, 02:15 AM | #2988 |
Rep 8,364
****NEW CODING****
For those who lost ability with for BLINKZYKLEN_ANZAHL_TIPP with I-STEP F025-16-07-501 Number of Soft Turn Signal Blinks PIA_DEFAULT_TIPPBLINKEN 00 = 1 blink 01 = 3 blinks 02 = 5 blinks All other tested numbers resulted in 00. Last edited by Almaretto; 12-15-2016 at 02:22 AM.. |
12-15-2016, 04:07 AM | #2989 | |
Rep 8,364
No separate code. |
12-15-2016, 04:09 AM | #2990 | |
Rep 8,364
You could check cable to make sure nothing is bent. |
12-17-2016, 12:51 AM | #2991 | |
Rep 69
Thanks. |
HZX540e373.50 |
