02-17-2015, 10:11 AM | #1 |
Rep 423
Vehicle Shaking 50i
This has happened to me several times and I really don't think it's an issue, just want to see if any other guys have the same thing.
When traveling at any speed when the vehicle shifts into the last gear (8th), does anybody else experience a shake in the engine when the accelerator is barely depressed. I think I know what the issue is, it's because it's in final gear and it's stumbling a little. Just like a manual transmission where you are going to slow in final gear. When I give it gas, it goes no problem. Probably dropping into last hear a little too early I expect. |
02-17-2015, 11:32 AM | #2 |
Rep 1,886
Here is a way to test your deduction: Drive in Sport, or Sport+ if you have it. It should upshift to 8th from 7th at a higher RPM. Or, it's your music (joke ends)
02-18-2015, 01:18 PM | #5 |
117
Rep 324
02-18-2015, 01:46 PM | #6 |
Rep 875
I don't have the 50i but it sounds like perhaps the engine is lugging a little bit as you mentioned? In other words, the RPM's are too low for the speed. Have you determined this to be a transmission issue or normal operation?
02-18-2015, 04:19 PM | #7 |
Rep 625
I had the same exact experience after a drivetrain malfunction and whenever I depress the gas pedal it rumbles
I am surprised your vehicle is not throwing a code "drivetrain malfunction" |
02-18-2015, 06:37 PM | #8 |
Rep 710
I agree. That is why the car has a torque converter and electronic shifting. There should be zero shuttering or the sounds of the engine lugging. The torque converter should be taking up the low-end rpm and converting it to transmission rotation fully around 1500 rpm or so. In addition, the clutches in the transmission should be making shifting butter smooth - from any speed or any RPM.
02-19-2015, 06:46 PM | #9 | |
Rep 423
02-19-2015, 06:47 PM | #10 |
Rep 423
02-19-2015, 07:35 PM | #11 |
Rep 710
Yikes - I still think it's an issue for the dealer to investigate...
02-19-2015, 07:37 PM | #12 |
75
Rep 342
I know echar you are talking about. Like ejem you remove the foot from the gas pedal it does it too. Like a vibration. As if the injectors needed cleaning to something. I noticed also that when you accelerate just a bit it doesn't have enough power and the engine shakes. Just like an old car.
02-19-2015, 11:18 PM | #13 | |
Rep 423
02-20-2015, 08:59 AM | #14 | ||
75
Rep 342
02-20-2015, 01:53 PM | #15 | |
Rep 423
02-20-2015, 04:02 PM | #16 |
Rep 132
I am having the same exact problem. Mine is around 40-45 mph if I am either staying at that speed (maybe a slight let off of the gas) or if I am just accelerating slowly (due to traffic of course). From what I can tell, it is not getting any worse. I am going to have them check it out next time I get the oil changed. Please let us know what you all find out.
12-07-2016, 10:59 AM | #17 |
Rep 93
Anybody ever get a final decision on what was causing this? I think my 50i just started doing this recently.
'14 X5 50i M Sport
MPBK | Meisterschaft GTC exhaust | H&R | V1 | IND | RG Sport | |
12-08-2016, 09:47 AM | #18 |
1150
Rep 2,426
I think the problem is you guys aren't flooring it. When you're trying to go top speed, the car never shifts to 8th gear.
Sorry I'm not much help, but I'll see if my car does it. How many miles you guys have?
2015 BMW X5 xDrive50i
BMW CCA 509766 |
12-17-2016, 03:18 PM | #19 |
Rep 30
I have a x3 35i that had been "jumping and jutting" at low speeds for a while (I told them in the past it has been always doing this) than I had a drive train malfunction and it would not move or start so when it got towed in they said the valetronic motor went and now it better but I think it still doing it but it's not as noticeable or often!
