04-02-2016, 11:00 PM | #1 |
Rep 25
Headlight Adjustment on startup
Please excuse me if this is a stupid question but...every time I start my X5 at night the headlights seem to go through an adjustment cycle. They pan from level to high, back down to low and back to level. Not like switching from low to high beam but rather smoothly like there is a movable reflector in the unit. I'm guessing there is a auto leveling system for the lights and it cycles through the extremes on startup. Anyone?
04-02-2016, 11:14 PM | #2 | |
Rep 289
all is fine. Every Xenon headlights do this regardless the car make/brand. Imagine the lights do swivell like this while you drive as well. that is so they do not blind the cars coming towards you. there are kind of "gyroscope" control units on the front axle that do this. to ensure the light hight level illumination is constantly at the same level/angle towards the road fo example if you are coming up a hill top /horizont it lowers the light patter down the road sonyou dont shine way too up blinding the car coming towards you should see Volkswagen xenons, they put up bigger show on startup |
04-02-2016, 11:16 PM | #3 | |
Rep 592
04-03-2016, 08:03 AM | #5 |
Rep 5,058
Yep, the lights swivel at start up to show that everything is working fine.. Once they stop swiveling at startup thats when you should worry.
fosterelli236.50 |
04-03-2016, 11:41 AM | #6 |
Rep 592
04-03-2016, 01:03 PM | #7 | |
Rep 1,181
Adaptive lighting, i.e. lights move when turning, etc., is standard. The master coding thread has the clear description of VLD.
04-03-2016, 04:15 PM | #8 |
Rep 25
Thanks for all the replies. My first time with xenon headlights and my search turned up nothing. Here's hoping they continue working as intended. Much appreciated.
04-04-2016, 03:58 PM | #9 |
Rep 743
04-04-2016, 08:04 PM | #10 |
1148
Rep 2,426
04-04-2016, 08:10 PM | #11 |
Rep 5,058
My 2007 & 2013 E60 also went up/down and side to side at start up.
02-10-2018, 09:22 PM | #12 |
Rep 2
Headlight adjustment
Hello community. this is my very first time ever creating a post. So please excuse if I am doing something incorrectly. In my case I had perfectly working and bright low beam.......until I took car to dealer for alignment.....after they done alignment, they forgot to reconnect leveling sensors by rear wheels....so they connected them back and now lights do level themselves, however low beam seem not being as fas as it used to be. Before I didn't even have to turn high beam, except when on very dark highways....I also remember, that before, when I turn lights on, they would level until certain point, and then go 2 more steps up. Now they just level to certain point (I couldn't see them doing those 2 steps up). Please advice, if there is any way I could raise them manually, or adjust that zero point (Idk how it is called)....Thanks everybody in advance....and I look forward for your reply people....
02-12-2018, 12:11 PM | #13 |
Rep 110
You can manually raise the beam, but please do it carefully so that you don't blind people driving at night. A good reference point is to raise the beam so that you still cannot see the heads of people sitting in another sedan (not SUV) about 100-200 feet from your car on a leveled surface. There is a white plastic screw hidden on top of the headlight on each side for manual adjustments. Just google it for the picture if the screw location.
