05-04-2022, 11:00 AM | #1 |
Rep 58
Help needed with N55 engine overheating
Good morning, we have a 2014 X5 x drive 35i with 130k miles
My wife got the below message today on our X5 after driving about 15 minutes. Engine temp gauge on dash shows normal temp (as seen in pic) and coolant tank is full. Could this be bad coolant temp sensor? Or is it more likely a faulty water pump/thermostat? Any suggestions on how to diagnose problem? Thank you. |
05-04-2022, 12:12 PM | #2 |
Rep 2,511
Temperature gauge on the dash is for the engine oil, not for the coolant temperature. Might be a bad sensor, thermostat stuck closed or water pump failed. You are at 130K miles so water pump/thermostat would be first thing to check. Did you ever do the coolant flush?
05-04-2022, 12:51 PM | #3 |
Rep 58
Thanks for your response.
I changed the coolant tank in August of last year at 116k miles due to a small crack in the tank, so I flushed the coolant at that time. Would doing the electronic coolant flush procedure be a good way to test the water pump? I also have Bimmerlink/BimmerCode - are there any good ways to diagnose the problem using those apps? |
05-04-2022, 02:16 PM | #4 | |
Rep 97
2018 X5 35i
05-04-2022, 08:50 PM | #5 |
147
Rep 334
Pull the code and see what it says. Thats step #1.
But at 138k miles I'd say your water pump and thermostat are due regardless.
2015 BMW X5 x35i | M-Sport | Alpine White
05-05-2022, 06:09 AM | #6 |
Rep 58
When I got home from work yesterday I checked the coolant level and it was actually below the minimum level, so I added some distilled water (maybe about 1/4 to 1/2 cup). After that I drove the vehicle for about 20-25 minutes with no dash warnings coming on.
Hooked up Bimmerlink and got code 20A701 - coolant pump speed out of tolerance. However it was a stored code and Bimmerlink said it was not currently throwing the code. Took the vehicle out again last night for about another 1/2 hour and everything ran fine. While driving I used Bimmerlink to monitor coolant temp, engine oil and water pump speed and everything was fine. Is it possible that the low coolant level could have triggered the engine overheating warning and the water pump code? What's strange is that in the past when the coolant level was low I got a dash notification saying to add coolant, which I didn't get this time. Or is it just the beginning of a water pump failure, turning off intermittently? |
05-05-2022, 10:14 AM | #9 | |
Rep 2,511
I would go with Pierburg, same pump just without BMW logo. You will save $250 |
05-23-2022, 07:37 AM | #11 |
Rep 58
All fixed. Replaced water pump and thermostat from FCP Euro. X5 running great again. Thanks for all the help.
jero121394.50 Florida-X3264.50 |
05-23-2022, 09:13 AM | #12 |
Rep 48
05-23-2022, 12:53 PM | #13 |
Rep 58
Yes did it myself following the FCP Euro YouTube video. Thermostat is easy once the fan is removed. Water pump wasn't too bad.. the hardest part was removing the top bolt. It's difficult to get to but I was able to reach it with a ratchet and flex shaft from the passenger side wheel well (I did not need to remove the wheel well cover to access the bolt). Other than that it was pretty straight forward. I would recommend having another person help with the fan removal/install.
I would imagine the dealership would charge at least 2k for parts and labor I did the entire job for $500 or so. |
HJ478.00 |
05-23-2022, 02:55 PM | #14 | |
Rep 661
floop20.00 |
05-23-2022, 03:51 PM | #15 | |
Rep 48
