10-27-2015, 10:12 AM | #1 |
Rep 9
E70 223m wheel fit on F15
Will E70 19 223m wheels fit on F15 msport?
I know e70 X5M rear wheel has a smaller CB 72 but 223m from m sport package should have same CB as F15 which is 74.1. Looking for a winter set on local used market. I want to make sure they fit before make the move. Thanks for your help! 19 223m wheels take from 2013 x5 m sport Rim Diameter 9 x 19 Front 10 x 19 Rear Offset ET 37 Front ET 20 Rear Tires 255/50 R19 (front) 285/45 R19 (rear) |
10-27-2015, 11:52 AM | #2 |
Rep 18,719
MAOP , it fits. As you as you confirmed that the rear wheel is 74.1CB.
10-27-2015, 11:53 AM | #3 |
Rep 174
I am no expert, just put your numbers into a tire/wheel calc, so...
Fronts seem Ok, the same wheel as on X5 F15 with 19" option. http://www.wheel-size.com/calc/?whee...=30mm&scl=50mm Rears seem Ok too - http://www.wheel-size.com/calc/?whee...=30mm&scl=50mm Did you check there are winter tires for these rims? |
10-27-2015, 11:55 AM | #4 |
Rep 9
I just called local BMW part department to confirm. They told me there were two 223m style package offered in Canada 1. square set up ET 37 all around. 2. stagger set up with rear wheels ET20. ET20 will be too aggressive for F15 as they have 48 ET. Is this correct? Thanks for your help!
10-27-2015, 11:56 AM | #5 |
Rep 174
Tire Rack has Pirelli Scorpion Winter RFTs for this staggared setup -
http://www.tirerack.com/tires/tires....omCompare1=yes |
10-27-2015, 11:59 AM | #6 | |
Rep 9
10-27-2015, 12:00 PM | #7 | |
Rep 174
Fenders - Tire will stick out 2 mm farther. Rim will stick out 4 mm farther. Acceptable for most cars Wheelwells - Will fill out the wheelwell by extra 5 mm. Acceptable for most cars |
10-27-2015, 12:32 PM | #8 | |
Rep 9
100% clear (leaves even more room than OEM) Rim will stick out 14 mm farther. Acceptable for most cars Will fill out the wheelwell by extra 5 mm. Acceptable for most cars |
10-27-2015, 12:39 PM | #9 | |
Rep 174
Your offset on your OEM 20" rears is 37, not 40. And rear rims are 11" wide, not 10.5". Here' the right link for you to click - http://www.wheel-size.com/calc/?whee...=30mm&scl=50mm |
10-27-2015, 12:53 PM | #11 | |
Rep 9
I believe the set I want to purchase has square set up 4 255/50 19 with ET37. I will check with the seller later on today to find out. I will ask him to measure the CB of the rear wheels just to confirm. It should be 74.1 as the set are form E70 m sport not x5m. The set he offered has Continental Winter Contact SSR Run Flat on it. |
