10-29-2015, 01:46 PM | #23 |
Rep 193
02-06-2016, 10:46 AM | #25 | |
Rep 570
Do you have notes somewhere or, DIY instructions, I would be interested in that. |
05-13-2016, 02:57 PM | #26 |
Rep 203
09-29-2016, 08:46 AM | #27 | |
Rep 2
How and where can this be done? I get that it won't be easy or cheap, but I'm willing to pay the price! |
11-22-2016, 02:35 AM | #28 |
Rep 203
I am in Germany now and maximum what I could do with European rear lights was to enable rear fog lights when I press brakes. Can someone please share how to code or rewire US Spec car to get European rear lights work properly?
08-16-2017, 07:02 AM | #29 |
Rep 99
Resurrecting an old- As I was washing my car an idea popped. So our F15s have two separate lamp housings,, one on tailgate and one on side panel. Both lamps will light up for brake and turn signal using the same red LED pattern here in the US. My idea is this- Can we disable the turn signal function on the tailgate- inner lamp housing? This way it will only light up as a brake light. The outer lamp will still retain both brake and signal function. This obviously is not a fix for those who want amber signals but neverthelss it can make it appear that we have a dedicated brake late in the inner housings. Hopefully one of our coders can have a Eureka moment on how to disable the inner turn signal.
10-06-2017, 08:38 AM | #30 |
Rep 1,011
just wanted to update on my 2017 f15 USA build i installed the euro switch and coded rear fog lamps successfully. i like it a lot and integration into the 6WB also swapped over with the OEM lamp light is very clean and i like that all the buttons on the lighting switch panel light up unlike on my f30 where it was dead unless you also swapped the panel.
retx117.00 |
02-03-2019, 08:04 AM | #31 | |
Rep 13
REM Module REM -> Mapping_Nebelschlussl_L_output: nsl_l REM -> Mapping_Nebelschlussl_R_output: nsl_r FEM_BODY 3060 NSL_Verbaut: verbaut |
02-03-2019, 08:34 AM | #32 |
Rep 1,011
i can’t confirm as it’s been too long and don’t have the car anymore. reach out to okee at codemycar.com for all your coding needs. he is amazing.
02-03-2019, 04:58 PM | #33 |
261
Rep 733
+1 ^^^^^
Okee is the go-to guy.
09-06-2021, 10:04 AM | #34 | ||
Rep 95
Drives: 2018 BMW X5 35i
2018 BMW X5 35i X Drive
2019 Honda Civiv Si coupe 2009 Yamaha FZ6R |
05-04-2023, 01:01 PM | #36 |
Rep 622
Drives: X5 F15 M package
Folks
I shipped my x5 to Europe and trying to figure out how to change the back lights and enable amber signal. I am not sure anyone was able to do it DIY. But I will be trying as it’s required to keep the véhicule here. I have the parts. Can anyone give me a 5 - 10 steps to do ? Much appreciated. |
05-05-2023, 05:03 PM | #37 | |
Rep 2,496
UPD: Found the thread: https://f15.bimmerpost.com/forums/sh....php?t=1699816 |
06-10-2023, 03:48 PM | #38 |
Rep 622
monkiboy are your back light working properly when breaking ?
06-12-2023, 05:36 PM | #39 |
Rep 622
Was able to code it all.
Now when I break the break lights are on. All good, I think ! Not sure if the EU regulation requires also the fog light to be on. I ll be told soon .. |
06-29-2023, 03:55 AM | #40 | |
Rep 622
Thank you for your help. |
06-29-2023, 05:57 AM | #41 |
Rep 131
Giving picture of EU Backlight (German car, but EU should be all the same, they are different for US-Spec and attempt of coding to EU-Spec will not work.
Rear Fog light has different postion, above lamps coded seem to be using flashlights for emergency braking. Next turn signal is white back-up light. -------------------------------------------------------------- Funny thing about this, I really like US-Spec backlight, no amber light, but one is never satisfied what one has LOL Last edited by chumbedi; 06-29-2023 at 06:06 AM.. |
