      06-12-2016, 03:44 AM   #1
coolidge
Drives: X5 xDrive 35i
Detailing question - water spots
Even though I have city water at home I have a horrible time with water spots especially on glass. Is there a detailing product I can use while its still wet to eliminate this issue? Or some kind of rinse product? Thanks in advance.
      06-12-2016, 05:27 AM   #2
Neuera09
Drives: 2016 X5 Xline with MPPK
I doubt there is a single product to eliminate water spots. I personally use chemical guys After Wash. It cuts my drying time in half. As for the windows, I use windex.
      06-12-2016, 05:35 AM   #3
aw305
aw305's Avatar
Drives: F97 X3MC Alpine White
As Neuera09 stated using an after wash spray as you are drying will help alot. I personally use a couple of sprays of quick detailer on each panel as I am drying. One towel in each hand one to absorb most of the water and detail spray and the other to buff out the remaining moisture. And I do this panel by panel. Also if you are able to do this process in the shade or inside of your garage that would be ideal.
      06-12-2016, 06:28 AM   #4
Terp335
116
Drives: E90 2011 335i M Sport
To echo aw305, make sure you're detailing in the shade and the paint is cool to limit hard water spots. The minerals most cities put in the water will do your clear coat and paint some serious damage if left to let dry in the sun.
      06-12-2016, 10:09 AM   #5
coolidge
Question: If I purchased jugs of distilled water to rinse my new X5 would other BMW owners point and laugh, "hey look at that guy it must be his first BMW"
      06-12-2016, 10:38 AM   #6
aw305
aw305's Avatar
@coolidge if you are serious they have inline water filters that attach to your hose line so that it filters and purifies the water as you are spraying down the car
      06-12-2016, 10:59 AM   #7
coolidge
Great tip aw305 I'll look into that definitely.
      06-12-2016, 11:25 AM   #8
Chem14
170
Drives: 2018 530e
A few of us have this and works really well.
https://www.amazon.com/DI-120-Cr-Spotless-Water-System/dp/B0056HDCUM
      06-12-2016, 01:03 PM   #9
Doanster
Doanster's Avatar
627
All of those product recommendations are good, but honestly, you can prevent a majority of the water spots from even happening by keeping the car wet as you work each panel/section of the car. That is, even if I'm washing/rinsing the back of the car, I'll spray water over the entire car so that other sections don't dry. This is more important if you are washing in the sun and/or heat.
Edit: using the water sheeting/cascading final rinse method def helps with spots along with saving on towel usage because much of the water is gone
      06-12-2016, 02:03 PM   #10
The CR Spotless is what you need. Used it and it works perfect. Say goodbye to drying your car!
      06-12-2016, 02:29 PM   #11
wifesbimmer
Drives: '20 X5 M50i, E92 M3, '16 F150
Another way to reduce spots is to have a water softener installed for your home.
      06-12-2016, 04:46 PM   #12
midlifecrisis
midlifecrisis's Avatar
804
Drives: 2017 X5 35d, 2019 230i X
Yes. And then we'd all run out and do the same thing.
2017 X5 35d (Performance Center delivery March 2017)
2019 230i X-drive
2022 M3 base
2000 328i sedan (UUC suspension - still the favorite), 2006 M3 slick top - Alpine White/Cinnamon
SOLD! 2008 E90 M3 SOLD! 1991 325iX (both great), 2019 Miata RF - various others not as memorable but gone.
      06-13-2016, 03:27 AM   #13
F15GorDe
F15GorDe's Avatar
Drives: F15d, F10
Metro Air Force makes the Master Blaster that reduces drying time by 75%.
Water spots never get a chance to start. Try treating your glass with Rain-X.
      06-13-2016, 03:22 PM   #14
double_j
85
Drives: 2008 JB/B E90 M3
All good suggestions above. Kind of obvious but the best way to avoid water spots is to thoroughly dry your car with a quality microfiber. Cheap terrycloth or most discount auto store microfiber will only push the water around...really good microfiber will leave all surfaces completely dry to the touch with only light blotting (me and a huge number of people swear by the guzzler waffle towels).
Rather than look for a product to apply while the car is still wet, just use that effort to completely dry the car. Using in-line water filters will help to avoid water spots for places you miss, as will making sure that you're not using too much soap in your wash water but the best way to avoid water spots is to not give them a chance to form in the first place.
      06-13-2016, 05:14 PM   #15
stewy604
stewy604's Avatar
289
^^ This.
2007 Suzuki GSX-R 750
      06-13-2016, 05:16 PM   #16
Originally Posted by stewy604 View Post
^^ This.
CR Spotless makes a lot more sense...
      06-13-2016, 08:11 PM   #17
Pastor Passum
Drives: 2016 X5xdrive
Absolutely. I'd never wash any car, motorcycle or lawnmower without drying it down afterward. I usually begin with my leaf blower or Master Blaster to get the water out of the nooks & crannies and finish with a good microfiber towel. Not a chance of spotting. Make sure never to use fabric softener or dryer sheet when washing your drying towels. They no workey afterwards if you do.
      06-16-2016, 01:02 PM   #18
roadkillrob
Drives: 08 335i,22 X3M, 2012 C63 Black
I always dry also with a leaf blower and then a microfiber, water spots are just a function of what is left over once the water evaporates, so you either have to get all the water of the surface before it evaporates or you have to filter the water so it is more pure - simple science!
2022 X3M Brooklyn Grey
2008 E93 335i FBO
2012 Mercedes C63 Black Series Alanite Grey
      06-16-2016, 03:57 PM   #19
coolidge
So is there a wax or finish that can help guard against water spots?
      06-17-2016, 01:36 AM   #20
Baunton
Baunton's Avatar
England
320
Drives: X5 45e 2021
I wash my car following this routine and never get spots even on (rare) sunny days;
1. Spray with Snow Foam
2. Spray Wash
3. Wash car using Meguiar's Gold Class Car Wash and Conditioner
4. Spray Wash off
5. Use Silicone Flexi Water Drying Blade - great for getting the roof done!
6. Dry and buff up using Micro Fibre drying towel
7. Stand back and admire!
      06-17-2016, 01:48 AM   #21
kanvas
kanvas's Avatar
Drives: V8
Would using clay work?
2014 X5 xDrive50i
      06-17-2016, 07:08 AM   #22
iconoclast
Self-Deprecating Narcissist
iconoclast's Avatar
7263
i would never use any of these squeegee blade devices on any vehicle. they work for the most part but that one time a piece of debris or gravel or sand or anything else gets caught... it will costs hundreds of dollars of damage. a filtered blower or similar would do a better job and not have risk of damage. (an unfiltered blower like a leaf blower may have a sandblasting effect depending on your area.)
