07-08-2017, 11:51 AM | #1 |
Rep 31
Why so hard on batteries info..
As a new owner of a x5 50i I had read about the need for batteries due to it being hard on them, found an article detailing why the need and the technical reasons. Hopefully this will help new owners, if this has been shared please let me know and I'll take it down... http://www.roadandtrack.com/car-cult...ns-bmw-n63-v8/
07-08-2017, 04:11 PM | #2 |
Rep 993
No clue, but I would guess it's also related to people who do short trips and use start/stop feature. They replaced mine at my last oil change. I hate the start/stop.
07-08-2017, 11:04 PM | #4 |
Rep 1,170
That's why I bought a battery tender. Hook it up every month and keep the battery in good health.
2014 X5 xDrive50i |
07-10-2017, 01:30 PM | #5 |
Rep 981
I wonder if this would be a concern in the F8x running in Sport+ mode. It adds a lot of extra cooling but I'm not sure if it extends the cool down period after the engine is off.
07-10-2017, 03:13 PM | #6 |
Rep 155
I think the real culprit is the short, frequent charging cycles the battery is subjected to due to the efficient dynamics programming. Battery life should really be defined in the number of charging cycles... it's probably the single most important battery stat behind current availability.
07-11-2017, 07:36 AM | #7 |
114
Rep 346
Not per the article - it is the tremendous heat soak created by the inboard turbo design that requires the cooling system to run for longer periods - that draws the battery down deeply and frequently. The "efficient dynamics" design contribution was handled by the AGM battery.
07-11-2017, 02:46 PM | #8 | |
Rep 155
Batteries typically don't mind deep discharges as much as frequent, incomplete charging. For example, your cell phone battery is probably rated at 1,000 charging cycles. "Charging cycle" is defined as anytime a charge is applied to the battery, whether its a partial or full charge. Charging once a day, you should get about 3 years of battery life expectancy. Charge more than that (which most people do) and it can shorten significantly. |
07-11-2017, 04:26 PM | #9 |
114
Rep 346
If that was the primary cause than most cars would be requiring battery changes at these frequent intervals - I believe it is the massive electrical draw associated with keeping the heat under control from this engine design.
Whatever the cause - it sucks... |
07-11-2017, 06:45 PM | #10 |
Rep 155
It definitely sucks. If I have to buy a battery at every oil change after December when my factory warranty is up, I'll be selling the vehicle.
It's both issues... deep discharge + short frequent charging cycles = battery never reaching a full charge, and an inability to keep up with the draw. After a while, there's not enough charge left in the battery. |
07-12-2017, 08:26 AM | #11 |
Rep 181
07-13-2017, 02:46 PM | #12 | |
Rep 1,170
You will still need to change up the batteries but what I'm doing is not so I don't change my batteries, but that I can lengthen its life by a little bit. The other day, I was surprised that it needed to be hooked up ~4 hours until full charge.
2014 X5 xDrive50i |
07-14-2017, 07:30 AM | #13 | |
Rep 181
07-18-2017, 09:00 AM | #14 |
Rep 535
No negatives. I put my 528i with "efficient dynamics" on the battery maintainer whenever I park it. When car went in for second service, the computer said not necessary to change battery, as most cars do. My wife's car has frequent short trips and if left to it's own devices, battery would never be fully charged. Key is a quality maintainer that doesn't overcharge. The BMW accessory charger is a CETEK, which is available on e-bay for half BMW's price. If you have a plug-in hybrid, the high voltage battery keeps the 12v battery charged up, so maintainer not necessary.
07-27-2017, 11:15 PM | #15 |
Rep 155
Talked to my SA about this today. The auto start/stop is the biggest drain on the battery according to her. She said the battery life is 3-4 years in the X5 with all the sensors, auto start/stop, etc... , but BMW is changing them more frequently to avoid any issues with customers.
07-28-2017, 11:29 AM | #16 |
Rep 256
I coded my auto start/stop off because I feel it puts extra strain on components...including the battery. My driving is mostly short spurts so hopefully I wont have an issue going forward once the factory maintenance is over.
2014 X5 50i
07-28-2017, 01:28 PM | #17 |
Rep 7,160
I've been using battery tender plus (Amazon) for years on my R1 and now my AMG that I don't drive often and it works great. Even have a lithium option because I'm running a Li- battery on my R1 because it lasts longer than AGM/cell batteries in between starts.
