      08-07-2017, 10:15 AM   #1
beachcomberx5
Drives: X-5
Price to install MPBK
Just curious on the cost to install, my dealer quoted $1200 which is 8 hours of labor which I think is ridiculous. I told him 4 hours should be enough but they are not willing to budge.
      08-07-2017, 12:54 PM   #2
beachcomberx5
Drives: X-5
Bump - trying to get an idea for purposes of negotiating a lower price with stealership.....unless someone knows a good Indy mechanic in central jersey.
Thanks
      08-07-2017, 01:11 PM   #3
Kzang
Kzang's Avatar
3239
Drives: 2015 X5 35i Msport SG
Look into RSW located in Green Brook, NJ ( central NJ ) https://redlinespeedworx.com/ . PM me if you want a contact.
      08-07-2017, 01:13 PM   #4
Eight hours? Wow...
      08-07-2017, 01:13 PM   #5
beachcomberx5
Drives: X-5
Originally Posted by Kzang View Post
One thing to consider is that after the adhesives are applied, the car needs to stay put for 24 hours to allow it the cure/dry completely before it is driven. Most people do a DIY to save money and also install using VHB double sided tape. I recently went RSW located in Green Brook, NJ ( central NJ ) https://redlinespeedworx.com/ to have mine installed for $200. PM me if you want a contact.
Thanks...but I was referring to the m performance brake kit.
      08-07-2017, 01:17 PM   #6
Kzang
Kzang's Avatar
3239
Yeah I edited my post after I read your original post again. They would still be able to install the brakes for you.
      08-07-2017, 01:18 PM   #7
beachcomberx5
Drives: X-5
Great thanks I will give them a call
      08-08-2017, 03:11 PM   #8
beachcomberx5
Drives: X-5
While I have been working with redline on an install quote, BMW Freehold called back and said their $1200 quote was to low. In order to install the MPBK they have to replace the brake guard which is held on by the hub bearings. When they remove the hub bearings they cannot be reused according to Freehold as they are somehow installed using some type of pressure and removing them ruins their functionality. So according to Freehold they also have to replace the bearings.
Has anyone ever run into this issue with the MPBK and the bearings Or is Freehold blowing a bunch of stealership smoke?
