08-08-2017, 12:53 AM | #23 |
Rep 251
If your X5 is new you should have the squeak & rattles warranty for the 1st year. I had the hatch rattling on my 2014 and kept bringing it back to the dealer till they fixed it. When it came back more recently I played with the round bumpers that someone above already mentioned and included a photo of. In my case unscrewing those bumpers as far as they would go (yes, unscrewing) did the trick.
08-15-2017, 12:06 PM | #24 |
Rep 557
Thread bump, still looking for anyone who has successfully resolved the center AC vent noise at start up. I know if I don't go to the dealer armed with the exact solution, they'll install a bunch of parts that won't fix it, claim it's fixed, and scratch up my interior in the process.
Here's a link to a video of the issue someone posted over on Bimmerfest. https://www.youtube.com/embed/MxSqDMVq_Fw |
08-15-2017, 12:17 PM | #25 | |
Rep 2,388
I'll try to listen carefully next time during start up - is it really subtle or noticeable easily? |
08-15-2017, 04:47 PM | #26 |
Rep 557
Easily noticeable. For me it's only when the AC is on that I've noticed. Quite a few people said they were having the same problem over on the Bimmerfest thread, and that the dealer had tried various fixes which didn't work. There was no solution posted.
DuSh2113.50 |
08-16-2017, 06:32 AM | #27 | |
kr0m3assass1n
1094
Rep 861
Drives: 22 X7 M50i
There are A/C goblins that live in the vents and they make noise when they like! |
09-07-2017, 09:47 PM | #28 |
Rep 36
squeaky dash
so I have the same issue with "vent noise" when my X5 M is warm-worst when sitting outside on a hot day. I understand SOME "cracks" as the temp is brought down, but for a 6 figure purchase...
I have played around with the trim when this is happening-for my ride, it doesn't appear to be the vents but instead it is the wood trim (around the vents and across the front of the dash). While it certainly appears to be temp related, I don't understand why the noise is so prevalent. I previously owned a 2011 550i and it was the most well built, quality car I have ever owned. Not a peep or squeak. I plan to discuss with my dealer, and will post any updates. |
08-11-2018, 06:03 PM | #29 |
Rep 4
Have a look at my post here: https://f15.bimmerpost.com/forums/sh...5&postcount=10
Might be the same issue that I had. The small clips holding the rear bumper (just under lower hatch) were rubbing each time I went over anything at an angle (eg car park ramps, driveway). A little grease and some plastic inserts fixed it. |
08-12-2018, 08:45 AM | #30 |
Rep 2,390
There is a SERVICE BULLETIN and a fix for the cracking/popping sounds from the vents. When I was complaining (again!!!) about poor A/C performance in my '17 F15, my dealer (Rusnak in Westlake Village) told me there is an official BMW Service Bulletin for the noises coming from the vents!
11-05-2019, 10:01 AM | #31 | |
Rep 536
11-05-2019, 11:34 AM | #32 | |
Rep 1,062
Drives: F15 xDrive50i M-sport
Two solutions. A.) Trade for a new car every time you hear a squeak. The new car will probably have at least one squeak, but it'll take you a while to notice it. You'll have a couple of weeks of perceived squeakless nirvana. B.) Switch to riding a horse. They don't squeak at all, as long as you ride bareback.
11-05-2019, 11:41 AM | #33 | |
Rep 1,062
Another noise source I tracked down was the sliding cargo lash-down hooks on the floor in the back. Tried a bunch of different positions, and even put little felt pads on them to try to get rid of the rattle they make on certain bumps. Solved the problem by taking them out of the tracks and wrapping them in a microfiber cloth and stashing them in the little pocket on the side. I seldom use them and when I do I only need a couple. Well worth the peace and quiet.
11-05-2019, 01:07 PM | #34 | |
Rep 536
The F16 is the first BMW I've ever owned with this many creaks, squeaks, vibrations and other assorted irritations. |
11-05-2019, 02:13 PM | #35 |
Rep 1,062
The OP totally had it coming. Cracking sounds out of a hot dash for 10-20 seconds after you first turn on the AC? A "rich guy" problem, and you've got to be a complete mechanical dunce for that to bother or puzzle you. What's next, a complaint that he can't hear his wife screaming at him when he puts the windows up?
11-05-2019, 02:21 PM | #36 | |
Rep 536
On top of this, there seems to be a TSB out for this. I think it's pretty much safe to say that this is not nominal. |
11-05-2019, 02:37 PM | #37 | |
Rep 1,062
I haven't owned a car yet - out of the 30-some that I've owned - that didn't make at least some minor creaks/squeaks/clicks when the AC or heat/defrost first fired up and the interior temp went up or down 60 to 80 degrees - like starting the car when it's -25. I live in an area where the highest high temp and the lowest low are 125 degrees F apart, which is probably a way more extreme temperature range than your area ever experiences.
08-23-2020, 12:13 PM | #38 |
Rep 12
My 2015 X5 is squeaking and driving me crazy. Given how wide spread this is, how do we turn this into a recall event. I spent $70K+ for my car. It should not squeak. My driver’s side door is squeaking now. BMW must have fixed the rear hatch last time I took it in for an oil change, because that is not squeaking anymore.
08-23-2020, 01:08 PM | #39 | |
Rep 536
