09-29-2020, 02:11 PM | #1 |
112
Rep 365
Anyone tried installing the KW suspension kit made for the F15 with self-leveling rear suspension and EDC? I am thinking about doing that on my 2018 X5 35d, as I find the OE setup to be terrible. I do some towing with the X5 though, and I believe that the KW kit lowers the ride height a bit, which is not ideal. I am not really looking to lower my X5, but if ground clearance and ride height are not changed dramatically I may be able to accept that in exchange for better ride quality and handling. Just looking for some opinions from folks who have tried this mod.
09-29-2020, 03:06 PM | #2 |
Rep 289
Can't speak to KW springs but I have Eibach Pro Kit springs on the front and lowering links on the rear air. Drop is a bit less than an inch, so fine for towing I would imagine, and nicely firms up the ride without making it harsh...
Eibach Pro Kit & Lowering Links, RC GTS Black 2014 M135i 3dr |
09-29-2020, 03:09 PM | #3 |
112
Rep 365
Thanks. I am looking at the full KW kit that comes with adjustable dampers, springs and EDC elimination modules.
09-30-2020, 02:20 AM | #4 |
Rep 289
As far as I am aware (and I stand to be corrected) there is no aftermarket suspension kit that improves handling without lowering the ride height unless you just get stiffer shocks.
From the specs the drop looks to be similar for both Eibach and KW so I still reckon it would be fine for towing. Does this kit stop the rear from auto-leveling? I would think if towing is important that you would want to keep this feature....
09-30-2020, 10:10 AM | #5 | |
112
Rep 365
09-30-2020, 01:39 PM | #6 |
Rep 289
Perfect, sounds like you are good to go. Assuming the drop is indeed the same as I have then it really shouldn't affect your towing in any way, it's a relatively small drop and the ride is much improved
09-30-2020, 05:29 PM | #7 |
147
Rep 334
10-01-2020, 12:35 AM | #8 |
Rep 289
Compared to stock, the OP said he has OE suspension with rear air (which is also what I had) so not M Sport...
10-01-2020, 09:20 AM | #9 |
147
Rep 334
10-08-2020, 10:54 PM | #10 | |
Rep 7,164
2) retaining self leveling suspension just means you only get sent 2 front springs. For The rear they send adjustable links to lower the rear to match the front drop. So in total it should be 4 shocks, 2 springs, 2 links, 4 EDC dummy plugs.
1230vani660.00 |
10-09-2020, 12:14 PM | #11 | |
Rep 289
1) the OP had said that he had OE and not M Sport, I did not say that you could not have M Sport and rear air. 2) I actually have Eibach Pro Kit springs on the front and the adjustable rear links, as I mentioned in my initial reply....(and in my sig)
Eibach Pro Kit & Lowering Links, RC GTS Black 2014 M135i 3dr Last edited by ems328i; 10-09-2020 at 12:20 PM.. |
10-09-2020, 12:20 PM | #12 | ||
Rep 7,164
10-09-2020, 12:25 PM | #13 | |
Rep 289
10-09-2020, 02:43 PM | #14 | ||
Rep 7,164
10-09-2020, 02:51 PM | #15 |
Rep 289
We don't get DHP in Europe. I'm pretty sure I don't have lsd or adaptive sway bars....sure as hell doesn't drive that way! Maybe you are thinking of 2VF?
10-09-2020, 03:26 PM | #16 | |
Rep 7,164
ems328i180.00 |
11-20-2020, 05:25 PM | #18 |
Rep 1,179
I'm not sure if I should ask this here or create my own thread. Would the KWs be an improvement over stock suspension w/o air/dhp etc for towing?
11-30-2020, 06:56 PM | #19 |
Rep 37
I recommend KW. My recommendation is that you have it professionally installed.. It's worth the cost.. The mom and pop shop cost me. I have a extra KW I will sell after the holidays as a result.. GMP in Charlotte did the work.
12-02-2020, 02:55 AM | #20 |
Rep 1,179
Can you elaborate on what the mom and pops shop did that cost you? Also, are you recommending that people don't DIY?
12-21-2020, 03:39 PM | #21 |
Rep 275
Looks great, what are your measurements in front and rear from ground to fender?
