11-18-2014, 07:20 PM | #155 |
267
Rep 345
Drives: 2019 X5 40i M
11-18-2014, 07:29 PM | #156 |
Rep 3,990
That is correct. Carbon fiber cannot have heat option enabled. Also, if you swap steering wheels, you have to make sure you get one with heating option if you want to keep your heating option. For example, going from a heated Sport wheel to heated M-Sport wheel.
11-18-2014, 10:08 PM | #157 | |
Rep 1,746
OK, forget what I said, I just searched and it was for older model BMW's BMW (627,615): 2000–2005 3-series sedan and wagon; 2000–2006 3-series coupe and convertible; 2001–2006 M3 coupe and convertible
11-18-2014, 10:20 PM | #158 | |
Rep 3,990
11-18-2014, 10:22 PM | #159 |
Rep 3,990
Also, please direct your steering comments/questions to the wrap thread so things stay more organized. Let's keep this thread for the 6WB . Thanks!
12-06-2014, 02:58 PM | #160 |
Rep 2,705
Saw 6wb on a F16 today. I can confirm that it looks sharper/better than on an F10. I want to do this mod now, with (again) a priority over performance package which is lame but i simply want it more, it looks fantastic. Have extended cluster which is nice (especially when it is using the white background during the day) but this thing 6wb will refresh the car and looks sooo cool imo. Not a super improvement over the F10 but a significant one (placebo effect maybe to some extent). Since i have a european vehicle if i do the normal service at the dealer (e.g. Oil change, brake change). I will not have to take out the 6WB cluster, correct? Cheers!!!
12-06-2014, 03:15 PM | #161 | |
Rep 420
The best car ever: E34 M5 3.8l daytonaviolettmetallic hos Mälardalens Ventilationsceneter
12-06-2014, 03:22 PM | #162 | |
Rep 3,990
Nope, it's not the same cluster. They are different parts. F15/F16 one is a little bit sharper for sure.
12-06-2014, 03:52 PM | #163 | |
Rep 420
What’s the serial nr of the one that bimmertech sells?
12-06-2014, 04:37 PM | #164 | |
Rep 3,990
http://www.etk.cc/bmw/EN/parts/info/...r/62109363265/
12-08-2014, 04:26 AM | #165 | ||
Rep 2,705
I am moving to the Netherlands soon, will drive the car there sometime in Feb or March 2015. As i am now in Austria, should I make a round trip to Poland and have it installed @bimmertech or can i do it myself. I know i can but ive never done any coding myslef and am afraid to do it. This mod is a must, can stop thinking about it. Cheers |
12-08-2014, 05:13 AM | #166 | |
Rep 3,990
12-08-2014, 07:48 AM | #167 | |
Rep 578
01-04-2015, 06:30 AM | #168 |
Rep 37
01-04-2015, 06:36 AM | #169 | |
Rep 37
I am driving the 2014 X5 M50D F15. If 6WB is available in Australia, is that mean when I get my panel it is just a simple swap with the multifunction panel rather then coding as well. Thanks! |
01-04-2015, 10:18 AM | #170 |
Rep 774
You will have to take it out. I had this almost done, but Bmw said that it will recognize this as false equipment and thus it will have to be removed every time, even though it is available for the 2015 model.
Has this info changed, or has anyone found out the opposite... and tested it? |
01-04-2015, 12:58 PM | #171 |
Rep 3,990
If it's a retrofit, you will still have to code it properly for the first time. Once the coding is done, then it is easy swaps between your 6WB and 6WA Extended or Basic cluster. That swap does not require further coding at all since all of the information is now in your car. However, if the 6WB is in the ISTA/P system, then you will not have to swap it. I would do this. Take your car with your 6WB. Make sure you have your 6WA with you, if it can't be read, then swap it out. That will tell you whether it's doable or not. Also post back so people know that if their dealer/country has 6WB option and they retrofit 6WB, they can keep it in permanently or not. Thanks.
01-15-2015, 02:31 PM | #174 | |
Rep 37
01-15-2015, 03:31 PM | #175 |
Rep 40,789
Try FDL Coding HU_NBT => KOMBI_AUFLOESUNG = aktiv.
2018 F06 Alpina B6 650ix GC; Space Grey; Vermillion Red Nappa Leather; Executive; B&O; Driving Assistant 2017 F15 X5 xDrive50i MSport; Glacier Silver Metallic; Black Dakota Leather; Executive; B&O; Driving Assistant; RSE Last edited by shawnsheridan; 01-16-2015 at 05:52 AM.. |
