10-31-2023, 02:11 PM | #1 |
Rep 11
NBT EVO repair_rest pb camera and carplay
Good morning,
I had my NBT EVO repaired because I had done something wrong in SSH. I received my NBT EVO everything works except the problem with the interface of my cameras and carplay. I no longer have the image from my front, rear, 360 and hitch cameras. I had saved my old FA, TAL, SVT. On the other hand, I realized that I was previously: - téléphone : TB-003.012.032 - Média: MB-003.008.011 -HMI : HB-006.007.032 https://f15.bimmerpost.com/forums/at...1&d=1698779265 and now I no longer have HMI -telephone: TB-003.008.011 Media: MB-003.008.011 https://f15.bimmerpost.com/forums/at...1&d=1698779265 Idem sur la version des cartes : Avant réparation : Road Map EUROPE EVO 2016-2 NBTevo_H16205I https://f15.bimmerpost.com/forums/at...1&d=1698779397 Et maintenant, je suis sur : Road Map EUROPE EVO 2020-2 NBT-evo_R19144I I kept my USB key with the activation of carplay + FSC file but impossible to reactivate it on the NBT. Can I do the manipulations via eSys? And how ? Thank you in advance for your assistance |
11-01-2023, 12:44 AM | #3 |
Rep 11
I do not know what to do. I downloaded Esys v.3.30 and PSdZData v4.43.21 on my pc.
Can you give me the data to do this? 1- reactivated my cameras (front, rear, right and left side and 360) 2- reactivated carplay Thank you for your help ? |
11-04-2023, 07:04 AM | #4 |
Rep 627
Drives: X5 F15 M package
Did you fix this ?
11-05-2023, 04:50 AM | #5 |
Rep 11
Good morning,
Not yet. I modified several options below under Esys via CAFD_00001EF6_006_018_014. But I still don't have the MENU with the camera on my NBT EVO. I can't get that in the photo I must have forgotten something!!! Codage fait: PDC_FLANKENSCHUTZ (aktiv) MACRO_PDC (aktiv) PDC_SENSOR_VORN (4_sensoren) car j'ai 4 avant et 4 arrière PDC_GENERATION (gen1) je ne sais pas la version de ma voiture MACRO_TV_C (aktiv) PDC_ABSTAENDE_VERSION (alt) PDC_DIRECTION (vertikal) PDC_SENSOR_HINTEN (4_sensoren) car j'ai 4 avant et 4 arrière MACRO_CAM_LEGALDISCLAIMER (id_mit_timeout) PDC_3D (nicht_aktiv) ACTIVE_PDC (aktiv) AUTO_PDC (aktiv) PDC_DARSTELLUNG_V2 (aktiv) ZIN_SEMI_PERMANENT_DISPLAYS_PDC_PMA (aktiv) MACRO_PMA_EINPARKEN (gen1) MACRO_PMA_AUSPARKEN (aktiv) COMMUNICATION_PARKMASTER à gen1 (au lieu de gen2) CAMERA_SYSTEM à trsvc (au lieu de icam_high) CAM_ECU = werte 01 (choix :? 1 / 5 / 11 / 25 / 255 MACRO_TV_C et MACRO_RV_C les deux = aktiv). PS: for your information, I had the camera and surround view before repairing my NBT EVO. Do you have an idea ? THANKS |
11-11-2023, 11:10 AM | #8 |
Rep 11
Hello TheNine90,
I coded the "VO" but I still don't have the cameras activated. I don't know how to flash and I don't want to do anything stupid. Can you help me ? I recovered PSdZData V4.44.20 Thanks |
