10-03-2016, 08:04 AM | #1 |
Rep 23
Steering Wheel Does Not Tilt
Went to get in my x5 today and the steering wheel is stuck in the upright position. The position when you park the vehicle. When I used the control lever it will go back & forth but not up & down. You can hear an audible click when you try to make go up or down but nothing happens. Any ideas before I drop her off at the dealership? Thx guys!
2015 BMW X5d
Black Sapphire / Black Dakota | M-Sport Pkg | 42 MPG Premium Pkg | Cold Weather Pkg | Driver Ass/Ass+ | HK Audio |
10-03-2016, 09:20 AM | #2 |
Rep 598
I had a similar problem. Mine stopped telescoping but tilted just fine. Dealership said they had to order the part but somehow reset something so that it worked until the part came in. Pretty easy fix though, took about an hour and covered under warranty. Hard to drive the car though
10-03-2016, 09:57 AM | #3 |
Rep 5,066
Had the same problem twice in the last several months... First time the dealer change the switch motor and the second time they were not able to replicate it and nothing was done.
10-03-2016, 09:28 PM | #4 |
Rep 256
Drives: '17 F15 MSport
Mine has done this a couple of times. I haven't had the dealer check it yet, the issue has corrected itself each time.
10-04-2016, 06:46 AM | #5 |
Rep 1,002
Same thing here. I banged on it pretty hard as I started the car, when it was supposed to be moving, and it is working again. It works now, but makes light buzzing noise as it moves. Haven't been to dealer.
10-04-2016, 07:27 AM | #6 |
Rep 159
My steering wheel just begin to make a clicking noise when it lifts itself into the parked position. Was this happening before the steering wheel stopped telescoping?
10-04-2016, 08:38 AM | #8 |
Member
11
Rep 88
This happened to me a couple of weeks ago. Hadn't owned the car but for two months and 4000 mi and the steering wheel was stuck in the up position. Would go back and forth but not up and down. Would only hear a click when using the tilt lever. Had to drive around for a week like this as I waited for my appointment at the dealer. Dealer ended up ordering and installing a new steering column. This took several days to get and install the part. Cost would have been around $2800 had this not been under warranty.
‘20 BMW M2 Competition
‘24 BMW i4 xDrive40 ‘22 Ford F-350 Platinum Power Stroke Super Crew ‘22 Jayco Pinnacle 32RLTS |
10-04-2016, 10:04 AM | #9 |
Rep 1,547
Haven't this specific issue, but I did have a problem (twice now) where the column squeaks and creaks when raising / lowering to position. Dealer has corrected both times.
10-04-2016, 02:40 PM | #10 |
Rep 159
This sounds more like what I'm experiencing.
10-04-2016, 02:51 PM | #11 |
<3 Flat Four
217
Rep 754
Did they say what they did to fix it? Mines doing some squeaks occasionally and would like to DIY instead of goin to dealers
10-04-2016, 03:46 PM | #12 | |
Rep 23
2015 BMW X5d
10-05-2016, 10:02 AM | #13 | |
Rep 11
I had the same issue over the weekend (F16/X6). It was very annoying and dangerous driving around with the steering wheel in the up position. I pulled a few fuses from the back and that corrected it. I'm going to take it to BMW this week. I'm also have an issue whenever I turn on the automatic high beam. I get a message on my screen "Camera-based systems malfunction." Two glitches on a car with only 6K miles. Scary.
10-11-2016, 02:59 PM | #14 |
Rep 23
Picked up X5 this afternoon after nearly a week in the 428i xdrive. They ended up manually "unjamming" the steering wheel and then reprogramming the steering column motor so that presumably this doesn't happen again.
Side note: They did put 5 miles on the odometer which I don't like but what can you do. Anyways, I've missed this beast. Cheers for the inputs guys!
2015 BMW X5d
11-03-2016, 01:31 PM | #15 |
Rep 23
Just an update. The steering wheel as AGAIN stopped tilting up and down. Luckily though it's not stuck in the upright position (like a school bus) so I'm not terribly mad. I will wait to take it in AGAIN to the dealer to be "fixed" when either something else breaks or I need scheduled maintenance. Still love the truck a ton despite this.
2015 BMW X5d
11-03-2016, 08:36 PM | #17 |
Rep 452
My had started to make a squeaking sound every time i turn on/off the car(when the steering wheel goes back to its original position). Besides that annoying sound everything works fine. Hopefully it doesn't go worse than that.
11-09-2016, 11:55 AM | #18 |
Self-Deprecating Narcissist
7266
Rep 6,561
did the dealer clear coding after repairing this issue?
11-09-2016, 01:20 PM | #19 |
Rep 5,066
My codes were still intact iconoclast.
iconoclast7265.50 |
04-13-2018, 11:46 AM | #21 |
Rep 56
My 2016 with 4,000 miles quit going up or down. Took in, said needed
a new column. On way home it started working. Part came in told them its off and on working. Hope they replace it with the new part. Sure is a pain with an hour in and getting a loaner |
04-13-2018, 12:41 PM | #22 |
Rep 648
Drives: 2016 F15, 2015 F83
Seems like the tilt/telescope feature has had issues on these vehicles. Mine is making a squeaking/grinding noise when you shut the vehicle off. This is the second time it has done it in the last year and a half.
2016 F15 X5 50i M-Sport
2015 F83 M4 |
