08-11-2019, 05:56 PM | #1 |
Rep 3
Help with part for Driver Seat Ambient lIghting
Long story short...
My son noticed the ambient lightning on the rear of the drivers seat was not working. I took off the rear seat panel and found the fiber optic cable was snapped apart. I tried to hack the two ends together with minimal success. Now I want to fix it correctly. I'm confused on what parts I need. According to this diagram it appears I need #16: Although it appears to me that it's only the housing of the fiber cable itself. When I search for the part number of the connected of the broken fiber cable 9240765-A102 I get the bottom image next to what appears to be the fiber cable I need but I can't get a part number. If anyone can't point me in the right direction, I'll buy you a beer. |
08-11-2019, 10:44 PM | #2 |
Freude am Fahren.
835
Rep 1,287
Drives: F15 X5 xDrive35i
It's hard to tell what are you looking for - care to share some photos?
And the easiest way to fix a fibre cable is using a juice-box straw
Freude am Fahren.
08-12-2019, 12:23 PM | #3 |
Rep 3
Here is the LED connector and the broken Fiber Cable. The part number on the connector doesn't look like it comes with the fiber cable:
#JuiceBoxStrawFTW Last edited by MMMII; 08-12-2019 at 02:12 PM.. |
08-12-2019, 02:19 PM | #4 | |
Rep 1,915
You can find the info here, I think! https://www.realoem.com/bmw/enUS/sho...59#63319240765 |
08-12-2019, 06:05 PM | #6 |
Rep 1,915
08-12-2019, 06:47 PM | #7 |
Rep 530
Drives: 2020 BMW X5 MSport Arctic Grey
11-22-2019, 01:15 PM | #8 | |
Rep 234
https://www.newtis.info/tisv2/a/en/f...ric/1VnY3IORPj Mine appears to be version 1, was the part number 52109180209 you ordered version 1 or 2? Also did it come with the fibre-optic conductor that you were able to just put into the LED connector? I thought about trying to superglue it back, but pretty sure that will block a lot of the light trying to come through the tube. |
04-09-2022, 04:56 PM | #9 |
Rep 2,513
happydude Did you end up fixing yours? Was cleaning my car today and found the same problem with my driver seat LED not working. Which one did you get? I don't have comfort seats and real OEM is a bit confusing on this. Part number 52109180209 seems to be for the comfort seats (shaft clamping rings) and I am having issues with finding version for basic seat with clamps.
Edit: Found it! Part number 52109180203 Last edited by RED_Y_; 04-09-2022 at 05:31 PM.. |
04-09-2022, 08:33 PM | #10 |
Rep 270
Drives: 2015 X5d M Sport Metallic Whit
I'm not sure I would ever have known about this ambient lighting on the seat back had I not seen this thread. Sure enough - a gentle white light is there in my 35d M Sport. Wonder what I'll discover next?
10-24-2022, 03:38 AM | #11 |
Rep 16
hi do u manage to pull out the broken fibre optic ? I have already buy the new fibre tube but can't manage to take out the broken tube
