02-18-2023, 06:36 PM | #1 |
Rep 18
Are this gaskets supposed to look like this?
I was getting ready to do couple fluid changes this Monday when I ran into this. I’m not sure if this gaskets are suppose to look like this. I just bought this X5 35i 2 weeks ago and the dealer told me they changed the valve cover gaskets. That’s it. Some help would be helpful. Thanks!
02-18-2023, 06:55 PM | #2 |
154
Rep 355
That isn’t a valve cover gasket shown in your photos. I see an oil pan with its gasket protruding - which is normal. That certainly was not changed anytime recently on this vehicle. An oil pan gasket job is very expensive and time consuming on this model.
The n55 engine has one seal that lives in a groove in the bottom of the plastic valve cover. |
02-18-2023, 07:39 PM | #3 |
Rep 5,022
Agree with the above and would add… prolly just some old oil leaked down from the previous failed valve cover gasket.
Wipe it down and check it next time. No really issues that I can see. |
02-18-2023, 07:47 PM | #4 |
Rep 18
Awesome, thank you very much for the quick responses. It was definitely some oil around a couple areas which I cleaned and going to have another look on Monday when I’m doing the fluid changes. Is possibly old fluid of when the valve cover gasket was changed so that gives me a little hope. Thanks again guys!
02-19-2023, 06:34 AM | #6 | |
Rep 18
Pics attached even tho they’re not the best photos |
02-19-2023, 06:36 AM | #7 |
Rep 18
02-19-2023, 11:09 AM | #8 |
Rep 2,525
Well if you can't spot the leak by looking at it, might be hard to spot it by picture. I would try to clean everything the best you can, let it sit for a day and then try to pinpoint location of the leak.
02-19-2023, 02:04 PM | #10 |
Rep 18
I cleaned everything yesterday. Those areas where you see oil where clean before that new oil appeared in the pictures
02-19-2023, 02:06 PM | #11 |
Rep 18
I don’t know how long ago the job was done. The dealer just told me that they replaced it. I cleaned everything yesterday to see if it was a leak and for my surprise there was oil in my garage after a couple hours.
02-19-2023, 02:37 PM | #13 |
Rep 18
02-19-2023, 02:44 PM | #14 |
Rep 630
I'm not sure about the N55... but on previous BMW i6 motors it was not uncommon for the plastic valve cover to warp and need replacement along with the gasket. At 92k miles and living in Texas I imagine it's a possibility.
02-19-2023, 08:21 PM | #15 |
Rep 18
02-19-2023, 08:34 PM | #16 |
Rep 630
02-20-2023, 09:23 PM | #17 |
Rep 18
Quick update. This is my garage after 24hrs. I know is not a crazy leak but definitely something to address right?
02-20-2023, 09:32 PM | #18 |
Insta~ f10_sapphire
158
Rep 412
If you can see the leak on the floor it must be very bad. mine was leaking alot aswell before but it never left a dot on the ground ever. The tray under it catches it and hides it. So for it to be leaking out the tray you should get it checked out.
Insta ~ f10_shapphire
02-20-2023, 09:37 PM | #19 |
Rep 18
I removed the bottom tray to try to locate the leak. So this picture is without the bottom tray.
02-20-2023, 09:54 PM | #20 | |
Rep 1,038
Because yes if you dripping this fast , get it looked at. Try some LM Molygen, that stuff is UV reactive. So wash the engine down, clean as much as possible. Fill with Molygen, and see where it leaks from. *Edit* You may have to clean a couple of times, to get all of the caked on/hard to reach places. Go for a quick drive after a clean to let it heat up, this will show any spots you missed. |
02-20-2023, 10:11 PM | #21 | |
Rep 18
02-21-2023, 12:19 PM | #22 | |
Rep 630
