11-18-2023, 05:53 PM | #1 |
Rep 20
Shark fin Removal
Hello All,
First off thank you to everyone for all the information posted up, it made great reading and i’ve learned alot from the forum. I’ve owned my late 2018 X5M for nearly 18 months and have my first worrying problem, I have a leak into the cargo area and after much trim removal I believe it could be the shark fin as water is runnng down from the headliner. Has anyone removed theirs before? Is it just stuck on or are their fixings under the headliner? |
11-19-2023, 07:47 AM | #2 |
Rep 463
It is glued to the roof. There’s several YouTube videos that show how to remove it, make sure to use a lot of tape around it and long box cutter. Be careful cause i stabbed myself really bad when boxcutter blade broke. But i doubt that could be your issue, i would look into roof rack maybe. It comes through the roof on both sides. Or even sunroof drains or water hose to the rear liftgate
11-19-2023, 04:08 PM | #4 |
Rep 102
11-20-2023, 02:09 PM | #5 |
Rep 20
The sunroof drains are clean and the gutters dry, it’s the first thing I checked. I wish the problem was that simple! Water is getting in at the back around the shark fin area and running down, water drips can be seen on the rear sunroof motor and frame then on the headliner in the middle and sides in that area. I can’t see it being anything else atm, I will complete the reseal of the shark fin this weekend, leave for a week and retest with a hose, then post back.
11-21-2023, 12:24 PM | #6 | |
Rep 463
Maybe try to lower ^carefully^ the headliner in the back and see. I am confident this is not it. Fin is sealed to the roof via urethane glue , similar to windshield, and then inside is the motherboard antenna piece, that also has a seal. Id check under the antenna/roof before you start cutting it off. |
11-22-2023, 02:18 AM | #8 | |
Rep 20
11-22-2023, 04:13 AM | #9 |
Rep 1,036
if you have the headliner dropped. Have you tried to put some UV dye into water and spray the crap out of the fin. With a black light you will instantly see if it is leaking. Just make sure to tape of the area so only the fin will get wet, and the water wont be running off onto the sunroof or roof racks.
The reason why Tony is trying to discourage you from ripping it off, is because its very hard to seal back up. If anything, you will create a bigger leak. |
11-22-2023, 03:57 PM | #10 | |
Rep 20
11-22-2023, 06:56 PM | #11 | |
Rep 463
11-23-2023, 10:46 PM | #12 |
Rep 225
I had trouble getting mine off, and I cut urethane for a living lol.
11-27-2023, 01:41 PM | #16 |
Rep 20
Thanks for the replies, I would rather avoid UV dye in case it stains. This leak is a proper head scratcher as it’s so far back. I had another look at the sunroof gutters after yesterdays heavy rain and they were completely dry. Anyway will keep the thread updated on my findings in case anyone else has this issue.
11-29-2023, 12:57 PM | #17 |
Rep 20
Quick update, yesterday I retested the roof before taking the headliner down. I started with pouring water into the sunroof drain gutters, all fine. Then pressure washed the shark fin, nothing and then the whole roof for 10mins and all dry inside… I assume it was the shark fin after all and the sealant needed more time to cure.. During testing it became apparent I have another leak.. Water is coming into the left side rear recess in the cargo area, this is leaking in via the seam at low level, more testing required but at least this one is manageable!
11-29-2023, 01:37 PM | #18 |
Rep 225
Urethane doesn't have to cure. Whatever was leaking after the reinstallation of the shark fin is still leaking. If the shark fin was leaking before removal, you should have seen where it was leaking when you removed it.
11-29-2023, 02:18 PM | #19 |
Rep 20
Confession time and you may laugh at me…: I couldn’t get the shark fin off. Blades kept snapping off and I spent 2 hours getting nowhere.. So I lost my cool, masked up the recess where the shark fin sits and filled it with Dow black weatherproof sealant. It looks neat, like a black gasket around the base a temp fix. Now I know this was the cause I will get it booked into a body shop and the sharkfin removed and reinstalled properly.
