03-25-2021, 05:18 PM | #1 |
Rep 1,694
Drives: 2014 428i and 2018 X5
HELP!!! IDrive stuck on blue flashing screen
Was starting to code the full screen CarPlay and it failed. Now idrive is stuck on blue flashing screen!
how to get out of flashing mode? The car starts, so that's good. Just seems stuck on this mode.
___________________ 2014 F32 428i M-Sport 2018 F15 M-Sport Last edited by ooshnoo; 03-25-2021 at 06:02 PM.. |
03-25-2021, 08:26 PM | #3 | |
Rep 1,694
03-25-2021, 08:33 PM | #4 |
Rep 42
I had the same situation it took me three days to fix. What I suggest that worked for me is that is possible that during the utility run the enet lost connectivity with the car so the flashing technically never finished. I suggest you run it again and hopefully the utility forces the Idrive out of the flash mode. If it doesnt work what I had to do was get a router in between the laptop and the obd port to ensure the DHCP was enabled and the car and the laptop never stopped talking and reflashed it and then it worked. Just some ideas to try.
ooshnoo880.50 |
03-25-2021, 08:37 PM | #5 | |
Rep 1,694
03-25-2021, 08:43 PM | #6 | |
Rep 1,694
Thank you so much! Why didn't think of that myself I have no idea
03-25-2021, 09:30 PM | #8 |
Rep 1,980
Drives: 2020 G20 320i M Sport
Just saw this now sorry!
Yes, if your internet connection is not stable it can causes interruptions in the process but re-running it will fix the issue. Enjoy your Fullscreen CarPlay
CMB Solutions Limited |codemybimmer.ca
Vehicle Diagnostics | CarPlay Solutions | Retrofit & Repair Consulting/Programming steve.ma@cmbsolutionsltd.com | www.codemybimmer.ca Online Store | Remote Coding Package| ID6 Retrofit for almost all F Chassis BMWs |
ooshnoo880.50 |
12-02-2023, 10:58 AM | #9 |
Rep 1
Bmw Blue Display
Hello, I also have this problem, the blue screen is stuck, so I want to restore it, I saw your comments, I want to know how to restart the software. It's just the first time I diagnose. Thank you
