12-19-2022, 01:10 PM | #1 |
150
Rep 349
Is there a DIY? SSD Upgrade for iDrive NBT Evo
Does a DIY exist for replacing the Toshiba HDD with a solid-state SSD?
My E70 is upgraded and I do not worry about a failure. The wife's F15 is still factory and mechanical hard drives only last sooo long... |
12-20-2022, 08:14 AM | #4 |
Rep 808
Drives: BMW X5 XDrive35i
Following! Techie here and completely agree, only a matter of time til failure. I wonder how we’d snapshot the software onto a new drive ? Hmm. Also, KC based here since I see OP is in STL.
12-20-2022, 11:35 AM | #5 |
Rep 661
If the HDD can be taken out, shouldn't we be able to directly "clone" it into an SSD?
Subscribed. We're going to keep our X5 for a long time, so this is something I'll also look into doing if there's a real tried and true solution.
2015 X535i - CP Piston, Manley Rod, ACL/King bearings, MILVs VRSF full charge Pipe, Wagner FMIC, Hybrid Turbo, MHD2+ VRSF DP, UR Front/Rear Sway Bars, Eibach springs, Bilstein B6
2015 MINI COOPER - Mahle Pistons, Max Rods, BMS intake, CTS charge pipe, Wagner Intercooler, ByteTronik Tune, VRSF DP 2017 540i - MHD2+, VRSF DP, TU Pump |
sukhk5272169.50 |
12-20-2022, 01:29 PM | #6 | |
150
Rep 349
I was able to simply clone the CIC, but QNX, Linux operations may be required here. A techno-savior would be invited to help us all out! |
