06-29-2023, 10:37 PM | #155 | |
Rep 28
If it's a replacement radar from original car that already has ACC function its gonna be direct plug and play tho. Good luck with that bro ! Btw i do have an extra BE2 ACC radar that i used earlier on cos i thought i bought a broken module (which wasn't the case, of course) Let me know if u are interested ya. |
09-19-2023, 09:30 PM | #157 | |
Rep 182
SaNGRia986.00 |
Yesterday, 10:19 AM | #158 |
Rep 595
Drives: 2018 F48 X1 xDrive 18D
Could somebody here provide me with a SVT.xml & the a .ncd of the ACC ECU?
Interested in retrofitting the radar sensor as the camera only is not optimal, but radar was never released for X1 F48 but if I have the coding files I might give it a try. |
Today, 02:31 PM | #159 |
Rep 1,351
Get a x6 ACC and do not flash. It will work without needing to calibrate. But you can default code it with your specs. I installed my radar from 750 , never calibrated or flashed and still works without any issue up to date
Please "Appreciate" If you like my post! DIYs : OEM Camera Retrofit, FLA Retrofit , Drive Shaft Ticking , Starting Issue, , F85 ACC Retrofit |
Today, 04:15 PM | #160 | |
Rep 595
Not sure if you or I don’t get it. F48 was never released with radar and it has an SAS ECU which is connected on S-can with KAFAS. Most of the DSC parameters(F15) are stored in SAS Ecu but not all. Either way I cannot calculate the VO because radar never existed on F48. So I have to manually FDL code all parameters, but first I need to know how to make it talk. If I can get the coding parameters sorted out, then I can see if I get an error because of missing radar. If you happen to have a list of FDL parameters between radar and non-radar that would also be very helpful. Yeah I was thinking to leave it instead of flashing once I get my hands on one. |
Today, 04:30 PM | #161 | |
Rep 1,351
As long as you have a parking assist you are good to go with SAS and DSC. If you can not add the 5AT and 5AR it will be hard to determine each parameter in each ecu. I do not have the non acc values anymore since i am on my new laptop with all new ESYS. But i can remote code the system for you if you are interested.
Today, 04:57 PM | #162 | |
Rep 595
I would like to upgrade to camera + radar based. I started mapping out the parameters here: https://docs.google.com/spreadsheets...kNFagMoek/edit |
