01-11-2022, 01:36 PM | #309 | |
Rep 211
17 X5M || 08 PS2 335xi
01-25-2022, 05:09 AM | #313 |
Rep 8,364
02-16-2022, 09:41 AM | #315 |
Rep 25
Just reading up on how the US is approving adaptive headlights as part of Biden's infrastructure bill made me remember I always wanted this feature. Researched the hell out of it but am pretty much terrified of doing any coding myself.
Are you still doing remote coding? Definitely something I'd be interested in paying a pro to bake into my 2018 F15. |
03-02-2022, 04:48 AM | #316 | |
Rep 8,364
Yes, I can do remote coding. |
03-02-2022, 10:27 AM | #317 |
Rep 162
Get it coded. Total game changer driving at night. You will smile every time you see the headlights rotate around or individually turn off the highbeams.
03-03-2022, 03:18 AM | #318 |
Rep 8,364
03-03-2022, 07:16 AM | #319 |
Rep 270
If you have used E-sys then the awesome Cheat codes produced by many of the fine folks on this forum makes the coding much easier. It's a must do mod if you have the LED headlights…love driving at night now just for the entertainment factor as anything
09-14-2022, 12:20 AM | #321 |
Rep 175
Hello
I want to install BMW 61316827372 Steering Column Switch in my F15. I will have to install it because I don't have a switch to turn it on automatic High beam assist. Does anyone have link with DiY how to change it? |
09-14-2022, 11:51 PM | #323 |
Rep 175
I have everything else. I have support systems with camera kafas , but because I have bixenon, I do not have HBA activated. I want to activate it according to the guide, but I have to replace the switch on the steering column, so I need DIY
01-19-2023, 11:44 PM | #324 |
Rep 234
Can someone confirm if anti dazzle will only work in conjunction with HBA?
I’m hearing conflicting information about compatibility with adaptive xenons. I’ve successfully coded in VLD and am interested in anti dazzle but not interested in purchasing a $750 clock spring to enable HBA. Unless I could just swap the switch itself and not the whole clock spring.
01-20-2023, 07:17 PM | #326 | |
Rep 234
I’ve spoken with a gentleman in England that confirmed he had anti dazzle with adaptive xenon. Unless that compatibility is only with eu-spec xenons, which I understand there’s a flap that na-spec xenons don’t have, and I’m wondering if this is why it only seems to work on LED lights. When you say not possible, is it because of hardware differences, or because it won’t accept the coding?
01-20-2023, 07:41 PM | #327 |
Rep 1,544
Hardware is different. US spec Xenons don't have the the walz
01-20-2023, 10:50 PM | #328 |
Right to Repair Enthusiast
93
Rep 115
Finally got around to coding the GFHB today with E-Sys and BimmerUtility. Very, very easy with the cheat codes (verified against the V2 PDF).
I feel like the low beams now are "lower" and maybe less intense than they were prior to the change. Like that the beam cutoff is lower than it was before. I could just be imagining this, but something about the low beams just don't seem as good as they were before. The GFHB itself works brilliantly, though. |
01-22-2023, 05:59 PM | #329 | |
Rep 7,488
VLD does change the driver’s side headlight from start up to around 30 MPH when it changes from URBAN to COUNTRY roads. Although when the F15 came along, BMW changed from the FRM to the BDC module in regard to the control module for lighting…but the concept remains the same as far as VLD function.
ArthurMorgan92.50 irzayev1.50 |
01-23-2023, 09:56 AM | #330 |
93
Rep 115
Thank you so much! That is exactly what it's doing. Every guide I've seen says to remove 8S4 from the VO - which appears to be the decoding/disabling feature for VLD.
I'm not a huge fan of what VLD has done in regards to my lowbeams. I'm sure it makes more sense in a more crowded European city with narrow roads and lots of pedestrians, but I'm not sure I really love how it works here. Is it possible to leave GFHB enabled but disable VLD? |
