      10-26-2021, 08:27 PM   #243
Blewx5m
Drives: 2015 x5m
Originally Posted by willzpatron View Post
Originally Posted by Blewx5m View Post
Originally Posted by PhillyX5M View Post
BlewX5m so you painted the bottom air scoop in red color?
Interesting. Definitely matches your car color nice.
Yes i did! I also did a carbon graphics on the engine cover n intake box i wanted the "afepower logo" left stock but my buddy messed up... I'm waiting to clean the car so i get some decent shots haha
Pretty fucking sick! I have a white x5m if I go with this intake I will be doing the same just in black color , how did he go about getting the intake and BMW motor cover done in carbon fiberINTERESTED IN THIS!
I had it hydrodipped but I wouldn't recommend it... Our engine gets too hot.. The graphics cracked so I just stripped it off
      10-26-2021, 10:21 PM   #244
willzpatron
Drives: 2018 x5m
Darn it sorry to hear that thanks for the info
      10-27-2021, 05:20 PM   #245
FirstBMWLA
FirstBMWLA's Avatar
187
Drives: 2007 335i Coupe
Originally Posted by KLR X5M View Post
Check to see you don't have any actual leaks in the intake system. Pcv hoses crack often in these and cause that code as well
Was pulling MAF sensors to clean today as I've had some persistent rough idle and hesitation going on after cold starts especially.
Was checking the crankcase vent hoses and in trying to disconnect the passenger side one the elbow on the turbo inlet tube broke off rather easily...
For now I have it held in place with zip ties.
Could be coincidence or maybe it was cracked there and that was the source of the code I had got.
Code has never came back.
Doesn't appear to be super hard to get to spot to change that inlet tube but seems to run fine how it is also...
This is tube that broke.
https://www.getbmwparts.com/oem-part...bC12OC1nYXM%3D
      10-28-2021, 09:25 AM   #246
KLR X5M
223
Drives: F85 X5M
They all crack like that. It's actually a pain in the ass to get to the inner bolt affixing the elbow to the turbo inlet housing. You have to remove the rubber hose couplings to the intercoolers and loosen the IC mounting to get at the bolts. I recommend doing both while you are there as I did.
      10-28-2021, 09:48 AM   #247
FirstBMWLA
FirstBMWLA's Avatar
187
What did you replace the one time clamps with?
Is wormgear good enough or tbolt?
That's been my issue in looking at changing it. I don't even see a tool to buy large enough to clamp the big Oetiker style clamps
      10-28-2021, 12:57 PM   #248
KLR X5M
223
Drives: F85 X5M
Using stainless worm gear for now, but will probably change them to constant torque t bolt style when the mood strikes. Generic worm gear seem to be holding stage 2 boost fine though.
      10-28-2021, 01:09 PM   #249
FirstBMWLA
FirstBMWLA's Avatar
187
Thanks man.
I figured worm style definitely work for inlet being Lower pressure
Was concerned about outlets.
Code came back about pcv vent. guessing the break caused it.
On a good note the MAF cleaning made a dramatic difference for issue I was experiencing. No stuttering/stalling on first cold crank of the day today. It was doing it very consistent before
I already bought the inlet duct from dealer earlier.
Try to swap it this weekend. Wish me luck
      10-28-2021, 07:43 PM   #250
FirstBMWLA
FirstBMWLA's Avatar
187
Swapped it this evening. Ended up not being too bad.
Made good use of extendable magnet to make sure I didn't drop a bolt or tool.
Loosened intercooler bolts as you said.
I mistakenly thought the inlet side had hoses but it was just the 2 screws on the end of the duct holding it in.
No tbolts at auto store so went with wormgear for now also.
