06-10-2023, 08:39 PM | #45 |
Rep 6
Hey Sophisticated Redneck, everyone else too, what do you guys think of this dudes setup venting the catch cans to atmosphere? Would this even work?
06-14-2023, 09:26 PM | #46 |
Rep 2,716
Drives: M3
Garage List 2016 BMW X5M [0.00]
08 BMW M3 [0.00] 14 BMW X5 50i - sold [0.00] 09 BMW 335i - Sold [0.00] 09 BMW 328i - Sold [0.00] 07 BMW 328i - Sold [0.00] |
I vent to the atmosphere from my oil cap vent… I also have two catch cans… it’s good either way!!
06-14-2023, 09:46 PM | #47 | |
Rep 1,019
If you vent to atmosphere, you wont be pulling a vacuum on the internals. Having a bit of a vacuum is beneficial to non at all. That's what that flapper valve inside the hose does, it's opens when the turbo's are spooling at pulling vacuum, but prevents blow back. |
06-16-2023, 06:42 PM | #48 | |
Rep 1,564
An alternative is to use exhaust evac tubes and route the CCV gases through it instead of just venting to atmosphere. You have the benefits of not smelling the CC gases in the cabin as well it will be burnt in the exhaust and the evac tubes can pull 5-6 inches of vacuum at full throttle. This will pull more vacuum then the turbo inlets and will effectively route all of the CCV gases out the exhaust at full throttle. There is also a mild HP bump from zero CCV gases being injected into the inlets and drastically lowers the changes of LSPI. Installing exhaust evac tubes is not easy however and requires dropping the exhaust and welding them in. I have been testing a few different methods to install the exhaust evac tubes without dropping the exhaust/welding to make it an easy to install kit anyone who can operate a drill can do. Will eventually come out with the weld-less CCV exhaust evac kit as well as complete catch-can setup worthy of being bolted on to an M (All-AN fittings, hidden screws, etc). Some early rough Prototype pics below with universal base, the F85/86 version will have specific base for best location & ease of install and be anodized in various colors and with or without the M logo. Have a couple of other projects I have to get out first though but will be releasing it this summer. Last edited by Sophisticated Redneck; 06-16-2023 at 06:52 PM.. |
mstgeer29.00 |
06-16-2023, 07:58 PM | #50 |
Just me
23
Rep 80
06-17-2023, 02:51 PM | #51 | |
Rep 97
06-18-2023, 08:57 PM | #52 |
Just me
23
Rep 80
I installed my catch cans yesterday vent to atmosphere with AN-10 fittings & hose
I also used a plastic cap (1inch I.D) to close the connection to the air intake system. So far what i can say about this setup is: Much better throttle response Lower oil temperatures Better sounding and deeper exhaust sound And hence i feel the engine is breathing much better Also i dont have any rough idle or check engine light or smoke from exhaust Find pictures attached: |
JRock80456.00 |
06-18-2023, 09:20 PM | #53 | |
Rep 1,019
Why did you choose to keep the flapper valve tho? If your venting out, isn't kinda redundant. |
06-18-2023, 09:35 PM | #54 | |
Just me
23
Rep 80
To prevent back flow of air from catch can system into crankcase during idle, deceleration. It also has a leak hole which is useful so i dont want to use just any non-return valve. During idle and deceleration, the engine gets rid of blow-by gasses directly into the intake manifold through holes in the cylinder head. So a bit of vacuum is needed in the engine during these times and hence the flapper valve will serve its purpose. |
06-20-2023, 05:18 PM | #55 | |
Rep 6
06-21-2023, 04:07 PM | #56 |
Just me
23
Rep 80
06-21-2023, 07:41 PM | #57 | |
Rep 1,019
If you are running catless, those most definitely reek if you have the windows down and are stopped or parked up.. |
06-22-2023, 05:51 PM | #58 |
Just me
23
Rep 80
Lol fully vaccinated 💪🏼, But on the hand maybe we all have different tolerances, as for me i dont smell anything in the cabin. Are you also running catless DP?
07-08-2023, 10:08 PM | #60 | |
Rep 97
08-19-2023, 09:29 PM | #62 |
142
Rep 352
Sophisticated Redneck I'm interested to buy one as well.
Thanks!
2016 435i M-Sport | Carbon Black | 20" 624M Wheels | MPPK | MPE | M Performance Brakes | M Performance Steering Wheel II with Display | xHP | Dinan Stage 4 | Dinan Big Turbo | Dinan High Performance Intercooler | Dinan Intake | Dinan Shockware | Fabspeed Sport Cat Downpipe | Custom Quad Tips | Autotecknic Red Paddle Shifters
09-04-2023, 12:15 AM | #63 |
Rep 1,019
Does anyone know what part of the PCV hoes fails that leads to it leaking oil? Replacing my turbo intakes that cracked and I've noticed that my bank 5-8 hose has allot of oil coming out of it and on the flapper valve inside. Banks 1-4 flapper valve is dry/no oil. I replaced banks 1-4 about 3k mile ago, as it was seeping oil where the hose bolted to the valve cover.
Just wondering what part of this hose fails that leads to it putting more oil into the intake. Does the hose have a filter or screen in it somewhere? Or is it the o-ring that seals the hose to the separator unit inside the valve cover? |
09-06-2023, 01:45 AM | #64 |
Just me
23
Rep 80
The hose itself is just a normal passage of filtered blow-by gasses from the stock oil seperator inside the valve cover to the intake to be burnt, but the hose has a built-in non-return valve inside which opens and closes based on vacuum
1. it could fail at the o-ring like you mention. the o-ring can shrink allowing leakage outside 2. or the hose can crack due to heat because its made of plastic 3. the non return valve inside the hose gets stuck either open or close (when i replaced mine it was stuck open) the results of this can vary |
09-06-2023, 05:40 AM | #66 |
Rep 1,019
Yeh, Maybe it's the o-ring, I did check the tube, and it looks solid. No oil was on it externally. The mess the previous failure created. It was all around the fitting. This fitting does not have any residue on the outside of the valve cover fitting, its bone dry.
I only noticed that there was an issue with that hose, after I removed the cracked boot hose and found allot more oil in it than on the other side. Looked inside the hose and boom, full of oil. The camera is not picking up the wetness that well. The other side, the colour is lighter(due to less oil exposure), but its also dry. There is also an oil stain on the compressor housing on the side of the PCV connector the intake boot. I think it maybe possible to bypass the separator unit, without removing it. I looked inside whilst I was doing the PCV hose and It looks like that o-ring seals the vent pipe to the separator unit. Insuring that only the air/pressure that went through the separator unit makes its way into the intake. So maybe an adapter that simply does not go in but bolts to the valve cover and lets all air/pressure out would be a good solution. Thoughts?? |
