06-02-2022, 06:28 AM | #89 |
Rep 94
Weldcraft has widened thousands of wheels (including many for track cars). The welds are said to be stronger than the rest of the wheels. I haven’t used them yet but that’s the plan. It only widens toward the inside so spacers are needed to get the space to go really wide. I was hoping there was room to add 1.5” to the rear OEM wheels but after looking at the gap I have with 15mm spacers in use, 1.25” may be the max.
My current tire sits about 15mm from the liner on the inside. The edge of the wheel itself is probably 25+ mm from touching. But the tire will sit wider on a wider wheel so the current 13.8” wide tire on a 11.5” wide wheel becomes a 14.25” wide tire on a 12.5” wide wheel. That’s probably going to take up every mm of wheel well. The front wells can take a 305/30/21 tire on an 11” wide wheel if the offset of the wheel is perfect. |
daytonaviolet1250.00 |
06-02-2022, 09:01 AM | #90 | ||
Rep 6,771
Drives: 2016 BMW i8
Garage List 2012 BMW e92 M3 [0.00]
2021 BMW X5M [10.00] 2015 Porsche 991 Tu ... [10.00] 2015 Porsche 991 GT3 [10.00] |
Cup2's are amazing on both track and the street until you get to standing water. They just can't channel the water. I swap to PS4S in the wet months. The grip level of PS4S is actually better on the street because they don't need heat in them to work. Cup2's start working with some heat (that's what the out lap is for - to heat them up before going 10/10th on lap 2 at the track).
Current BMWs: 2022 X5 40i, 2016 X5 50i
2015 Porsche 991 Turbo S 1979 Porsche 911 Turbo (930) a couple others IG: longboarder949; YouTube: https://www.youtube.com/channel/UCT1...eoFBszPIK0gf9w |
06-03-2022, 12:35 PM | #92 | |
Rep 1,233
Mixing compounds
It's not advised to mix compounds. If you push the MPSSs on the street before warming them up, they're slippery enough. Never mind putting a slicker tire on the rear for potentially more slide/oversteer. (Most people drive chill enough that they'll never notice the difference, but it doesn't take that much to push these tires, you can feel it when it happens too.) Could be fun, just be careful! And keep us posted. |
06-09-2022, 11:31 PM | #93 |
Rep 1,252
Had Dinan springs installed. I think it gives it the perfect drop, as the roads here aren't always the best.
I'll take some pictures soon. I also installed a Vargas crankcase breather. It's made really well and is on sale now, so picked one up. Thanks for the suggestion Cbozz |
slow_roll109.00 |
06-10-2022, 01:04 PM | #94 | |
Rep 117
9vapors651.50 |
06-11-2022, 01:48 PM | #97 |
Rep 1,016
9vapors,
How did you code the anti-dazzle feature? I sent you a PM.
9vapors651.50 |
06-11-2022, 02:25 PM | #98 |
Rep 94
Had Discount Tire take the 15mm spacers off the rear. These giant Pilot sport cup 2‘s now gently touch the liner in 1 spot (should burn off in a few miles) and they’re tucked a couple mm’s from flush. If anybody wants to swap 5mm H&R spacers for 15mm let me know.
06-11-2022, 03:54 PM | #99 |
Rep 1,252
06-11-2022, 06:04 PM | #100 |
OEM CSL Whore
1250
Rep 1,476
9vapors651.50 Blue By You631.00 |
06-11-2022, 07:21 PM | #101 |
Rep 175
Anti Dazzle coding service..
https://bimmer-remote.com/products/a...hts-coding-f-g Got mine done from them today. Really easy and it's a remote service so all you gotta do is get the e-net cable from Amazon and run windows 10 on a laptop |
9vapors651.50 |
06-13-2022, 05:30 AM | #102 |
Rep 1,016
slow-roll,
Thank you, this is much appreciated.
06-13-2022, 10:44 AM | #103 |
Rep 1,233
Anti-Dazzle
Thank you for the video.
I'm on a 2017 F85. I tried this a couple of times on BimmerCode and I did not have the same menu options as he mentions in the video. Same thing happened to me on the soft close trunk lid, BimmerCode lacked the same menu items so I couldn't code it. Anyone have a similar issue and can offer any help? |
06-13-2022, 12:02 PM | #104 |
Rep 1,016
I have looked at Bimmer Remote Coding, and this feature isn't available to the F85. or at least I didn't see it offered as a compatible vehicle.
06-13-2022, 12:23 PM | #105 |
Rep 1,233
F85
06-16-2022, 12:41 PM | #110 |
OEM CSL Whore
1250
Rep 1,476
I've been following:-)
2017 X5 wide body and carbon fiber build倀 https://f15.bimmerpost.com/forums/sh....php?t=1884277 |
