12-16-2022, 02:11 PM | #1 |
Rep 48
f15 self levelling headlights
Hi. I’ve noticed a few times lately that my self levelling headlights (when they do the up and down on start up) only the left moves initially and then tries again straight away. At this point they both move and all is ok. What could this be please? Thank you.
Bish
12-16-2022, 04:35 PM | #2 |
Rep 7,485
It may mean you not only have self leveling lights…but you may have an upgraded headlamp option like adaptive LED headlights with VLD (variable light distribution).
Do you know what headlight option (code) you have? The video below shows the VLD initiation movement at start up: What happens if you start up and then put the car in drive, then reverse…does one of the headlamps move every time you change from drive to reverse (see video below)? VLD…left headlight moves when you go from drive to reverse, back to drive then reverse, then back to drive:
Become a BMW CCA member! Click HERE to join and feel free to use my BMW CCA member #191509 as a referral. Last edited by Qsilver7; 12-16-2022 at 04:41 PM.. |
12-19-2022, 06:56 AM | #3 |
Rep 7,485
Since there was no response from the OP…don’t know if they got the info above yet…but again, the LED headlights go through a “reference run” upon engine start up. If the above videos is what you’re experiencing then they are acting as they should.
Here’s another description of the reference run that occurs on engine start up: Engine start
12-19-2022, 07:02 AM | #4 |
Rep 48
Yes that is what they used to to. But occasionally only one moves (left) up and down the other not. Then the left and right move together as normal straight after. I’m unsure what is happening to the right one when it doesn’t move.
Bish
12-19-2022, 07:36 AM | #5 |
Rep 131
Maybe sensor defective, check in bimmercat for your model / headlight what all is available in the headlight. Have you checked cables at 1st? Hopefully only loose connection
12-20-2022, 06:19 AM | #7 |
Rep 131
12-22-2022, 06:22 PM | #8 |
Ground Clearance?
232
Rep 1,651
i wouldnt say anything is defective. the car is running its checks and if youre not getting a fault then nothing is wrong. also if you have the wheels turned it will do a different "dance" than it normally would.
E90 330i - E90 335i - E92 335i |
