04-11-2023, 01:11 AM | #89 |
Rep 167
I know what you mean, but I guess from RK's perspective there may be an issue with releasing previous customers' info. If they willingly and easily provided this info then that may lead me to be concerned with their overall business practices/integrity.
04-11-2023, 10:25 AM | #90 | |
Fueled by Recycled Dinosaurs!
630
Rep 1,171
Drives: F06 M6
2015 F06 M6 Silverstone Metallic II, Individual Full Leather, B&O, Night Vis, CCB, RKAutowerks (CP Rods/Pistons, DI Cams, CF Intakes, Coated DP's & Billet Diff Brace), InfinityAuto Turbo Inlets, Mishi Oil Cooler, JB4, XHP S3, BM S3
04-11-2023, 11:42 AM | #91 | |
630
Rep 1,171
Drives: F06 M6
I Luv BMW90.50 |
04-11-2023, 10:12 PM | #92 | |
Rep 167
Latest update is - spoke to my mechanic, they are still in the process of stripping down the engine and said to hold off on the RK motor for the moment. Given the engine needs to be stripped down to accommodate the engine replacement anyway, they will check to see whether the block is rebuildable, and run a cost/time/quality analysis of a rebuild vs buying an RK rebuilt long block. I was keen to make a definitive decision sooner rather than later (have been without the car for about 4 months now) but I guess I need to be more patient. Realistically, I am thinking one way or another I won't have the car back for at least another 2-3 months. |
TinCanSailor629.50 |
04-11-2023, 10:59 PM | #93 | |
630
Rep 1,171
Drives: F06 M6
These engines make fantastic power plus BMW M curb appeal is nothing to sneeze at. Terribly sorry to hear that you have to go through this but your patience will benefit you greatly down the road.
I Luv BMW90.50 |
04-11-2023, 11:45 PM | #94 | |
Rep 167
Long and painful lesson learnt, and completely with you on the M appeal, I guess this is why we get these cars. Replacing this car with a non-M car is still a very real possibility, but I just know that every time I drive past a BMW M it will just leave me yearning. But here's to hoping for positive developments in the near future. |
ArthurMorgan92.50 |
04-12-2023, 03:27 PM | #95 |
Rep 60
Drives: 2018 F85 X5M
Sorry about your engine issues. I have the stage 2 bootmod tune on my F85 and you have to make sure you are using high quality oil (I use Motul Competition oil) every 5k. It's a bit pricey but worth it. You also need to change the spark plugs every 4-5k as well. I know it may seem like overkill, but when you are adding an additional 150hp+ it's more wear and tear on the engine. Another huge factor that has already been mentioned is letting your engine oil heat up before getting on it. I know it's a pain and takes at least 10+ minutes or more to heat up, it's part of keeping your engine healthy.
I would also check out Pure Performance in Texas. They do complete engine rebuilds and are a solid company. Their site is kindy wonky and doesn't always work. But you can check out their instagram page @pure_performance_tx It's another similar option to RK Autowerks. Cheers! |
I Luv BMW90.50 |
04-12-2023, 10:51 PM | #96 | |
Rep 1,019
04-13-2023, 12:30 AM | #97 | |
Rep 167
Watching this video made my head spin. The only "work" I ever did to a car was changing the air intake on a Suzuki Swift Sport to a K&N CAI (this was back in the Fast & Furious days) and I was pretty impressed with myself. Granted, this vid is a Stage 3 build but I would imagine the process is the same for a stock rebuild, so I can now understand why BMW and most indies just recommend engine replacement instead of rebuild. |
04-13-2023, 01:04 PM | #98 |
630
Rep 1,171
Drives: F06 M6
A lot of work and specialty parts go into a Stage3 build. Seems there is no shortage of M owners looking to build the next 1000HP+ car these days. I am glad we have folks out there willing to endeavor into that territory as it does help raise the level of knowledge even amongst the daily driver enthusiasts. Those sorts of builds have helped me focus on maintenance and parts that will help the car live a longer and more reliable life. A person really should have to know how to work on their car in order to properly enjoy it but being involved can help identify things before they escalate or help prevent repair scams.
Everyone in my household takes part in general maintenance, it is not always easy but it has been fun sharing the experience with my wife, daughter and son.
04-13-2023, 10:00 PM | #99 | |
Rep 1,019
Here the slower version, Raza goes abit into what they are actually putting in. |
04-14-2023, 12:20 AM | #100 |
Rep 167
I actually watched that one as well. Hearing Raza talk gave me confidence in his product. When the time comes, and I can get over the wire money transfer hurdle, I will be ready to pull the trigger.
04-16-2023, 09:18 PM | #101 |
Rep 167
Latest update
Latest update: Engine has been totally stripped down and all parts will be sent off to a machinist to see what might be possible. Initial thinking is that the block can be rebored and fitted with oversized rods and pistons, but will need to wait to hear back.
The photos show: - Damage to main bearings - Scoring of cylinder walls - Crankshaft scuffing - Rods and bearing mostly destroyed At this stage, mechanic is recommending a rebuild if possible, on a cost vs benefit analysis against a junkyard replacement. The mechanic is now inspecting all other components which may be replaced while the engine is out. Will hopefully have an update this week. |
04-16-2023, 10:39 PM | #102 |
Rep 1,019
Ouch, thoughts and prayers go out to your machinist and your wallet. Based on the #4 main, start exploring plan B options for block and crank.
If he manages to recover that, please me know he is. |
04-16-2023, 10:56 PM | #103 |
Rep 167
All over, red over you think? If they can be recovered, how much would you expect ballpark?
Seems this might all become a fruitless exercise so maybe junkyard engine is the only option now. |
04-16-2023, 11:33 PM | #104 |
Rep 1,019
Lets hope the photos are making things look worse than they are. If you mechanic thinks is salvageable and your machinist agrees. Without measuring things out, vs BMW spec and main bearing options. It hard to say.
I don't want to set you on the wrong expensive path here. |
04-17-2023, 12:05 AM | #105 |
Rep 167
No worries, and appreciate your input nonetheless. The mechanic seems to think that a rebuild, assuming it is possible, will work out a similar cost of a junkyard engine ($20K+). This doesn't seem completely unreasonable given PPM racing is was selling that stroker kit for about $15K (they never replied). So mechanic is suggesting the rebuilt would be worthwhile, and this will give me the option of driving the car longer term or selling it. Using the junkyard engine will mean selling it immediately.
They are working up a full parts list so will hopefully hear something soon. Real sick and tired of this now. |
04-17-2023, 01:13 AM | #106 |
Rep 1,019
Honestly, not to cry wolf. I would start thinking of plan B.
That #4 main bearing(the one without an actual bearing, white shim looking things), looks like it went into full free spin mode. You can see how it gouged into the block and out the other side. Top left of the bearing there is a very square(factory machined) bearing holder groove, look at the bottom right. The main cap's bearing dug into the saddle, gouged out it's own track, free spun and came out top right. |
04-18-2023, 01:31 AM | #108 |
Rep 167
Looking into Plan C options. Used block from seller in Germany. Approx $6.5K delivered. Block itself is from a car with 70K KM. The seller sent me 2 videos of the block, which I have uploaded to Youtube.
How does it look? I would obviously need to supply the crankshaft, cams, rods, pistons e.g., everything else. https://youtube.com/shorts/_LhxhLb2rVg |
04-18-2023, 06:43 PM | #109 | |
Rep 1,019
The slight concerning for me, would be the main caps 2 and 4. Near the oil line(the hole), there seems to be either some dirt/oxidisation or actual wear on the block. If it is wear, then depending on how bad it is, could need fixing. Show these to your mechanic/machinist, see what they say. If they can/its possible to hone these mains. Also, if you going with a just a diff block, double check your head situation. You mechanic took some good photos. On the cams, you can see some wear lines, they look ok-ish, just could use a slight polish. The question I would have is, how are camshaft journals/caps? These don't have the sacrificial bearings like the rods/crank. Would want to double check their state, as you cant machine cams/caps. From an T&M POV, a full LB seems to make more sense. Maybe the local junkyard is not such a bad option. Just a quick look over(check the bearings, put in acl/king/etc) and drop in. No machining, special order parts. |
04-20-2023, 01:08 AM | #110 | |
Rep 167
This is resonating more and more as time continues to pass and patience wears thin. My thinking is that if it looks ok from a check then I will upgrade some of the internals with intention of driving the car long term. If it does not look that great, then just use the engine as is and flip it. Perhaps upgrade both the rod bearings and the rods? Correct me if wrong, but my understanding is that: - The rod bearings can be replaced through just the bottom end (i.e., without pulling the block apart) - The rods can only be replaced through the top end (i.e., need to pull apart the block). |
