08-07-2016, 12:14 PM | #1 |
Rep 621
Lane Departure Warning Vibration
Hi All
Not sure if I have an issue here. Basically I find the vibration on the steering wheel when LDW activates to be very weak. Most of the time I find it hard to register it when it starts. In fact it seems to make an audible sound which I tend to hear more than feel the vibration. In my previous F11 I could set the vibration intensity and found it more easy to notice and more refined in operation. The F15 doesn't seem to allow the vibration intensity to be changed. Currently I'm debating turning it off as it's so lackluster and I find the noise it makes irritating Anybody got the same? Perhaps mine is faulty? |
08-08-2016, 12:22 AM | #6 |
Rep 8,364
The only auditory sound I get is from frontal collision warning. I disabled my LDW because I found it very noticeable, overly sensitive, and annoying. I like my blind spot triangles.
08-08-2016, 05:42 AM | #7 |
Rep 137
Hmmm I get no sound from my frontal collision warning, only the light on the dash, which doesn't do much to get my attention. I am going to have to ask dealer about that when I go in for first service in a few weeks.
08-08-2016, 12:42 PM | #9 |
Rep 8,364
It starts as red car in HUD but if you do not brake it will then make sound and then brake.
08-08-2016, 03:33 PM | #10 |
Rep 50
08-08-2016, 03:37 PM | #11 |
Rep 137
08-08-2016, 03:39 PM | #12 |
Rep 8,364
08-08-2016, 06:58 PM | #13 | |
Rep 256
Drives: '17 F15 MSport
If it brakes for you, you are about to hit someone / something. If you have not experienced this yet, you are not driving aggressively. Trust me, you will know it when it kicks in, the braking is not gradual or light. |
08-18-2016, 04:27 PM | #14 |
Rep 8,364
The Driving Assistance algorithms are very complex. So much so that blind spot detection does not just indicate when a vehicle is directly, but also may be in blind spot based on your and their speed.
Similarly, I had my frontal collision warning with braking kick in last weekend when I was at least three cars from vehicle in front and it is definitely not subtle. It was as if brake pedal was floored. I am glad the person behind me was not tailing too closely because I would not have chosen to brake at the time and could have been hit. I quickly adjusted the warning off of "early" and plan to check the parameters to see if one is better suited or I will disable completely. |
08-18-2016, 06:24 PM | #15 |
Rep 1,201
The frontal collision warning only makes beeping sound and brakes for you if you are very close to the car in front of you who suddenly slows down or stops. Out of the 1 year ownership I've only experienced that once, and it's definitely not a situation you want to be in all the time
2022 X7 M50i Phytonic Blue
2019 M5 MBB (wife's DD) |
08-18-2016, 07:22 PM | #16 | |
Rep 8,364
08-18-2016, 08:41 PM | #17 |
170
Rep 386
08-20-2016, 08:24 PM | #18 |
Retired Curmudgeon
2985
Rep 4,047
I have mine set to the middle setting. I have to get pretty close before the red car shows up on the heads up display.
'19 X3 M40 Carbon Black/Oyster, '23 Jeep Grand Cherokee L Summit, Past BMWs: '18 M550i, '18 330 GT, '16 X5 40e, '11 E90M3, '06 X5 4.4, '03 330i ZHP, '02 M3, '97 Z3 2.8, '95 M3 (2x), '94 530i (manual), '92 525i (manual), '88 M3, '87 325iS |
08-20-2016, 11:32 PM | #19 |
Rep 8,364
I had mine set to early. Depending on speed, visual in HUD followed by auditory warning showed up both when further way at faster as well as up close at slower velocities. I did not mind the visual and auditory warnings, but did not like the braking when not as close. So, I switched mine
08-21-2016, 11:03 AM | #20 | |
1150
Rep 2,426
Now I wish I got night vision too, but I guess next time. |
08-21-2016, 03:12 PM | #21 |
Rep 8,364
It is definitely nice when it works as it should.
