08-25-2016, 05:54 PM | #2707 | |
Rep 10
Regarding the GFHB, I am 100% sure that it is not working. Maybe being "not Active" is more appropriate word for my case. The reason I am sure is that, whenever I approach a car from back, or another car coming from other direction gets close to me, the headlights turn off automatically and turn back on when they are not near. This can also be verified from blue headlights indicator in my cluster being turned off/on. Also I have never seen my headlights make a tunnel, whenever there is a car in front. So I suppose it is not active. Thanks again, and I am really happy if you can help me |
08-25-2016, 05:58 PM | #2708 | |
Rep 40,752
shahdad.lotfi0.00 |
08-25-2016, 06:00 PM | #2709 | |
Rep 10
08-25-2016, 06:02 PM | #2710 |
Rep 40,752
Do you have 814 in FA, which is NATIONAL VERSION ITALY?
shahdad.lotfi0.00 |
08-25-2016, 06:06 PM | #2711 |
Rep 10
08-25-2016, 06:14 PM | #2712 |
Rep 40,752
None of that would do it, and I ran your VIN, and I see nothing else in your FA that could be restrictive. If it i snot working, it does not appear to be becuase it is being disabled. I would ask dealer if it should be working from factory or not.
Neuera09278.50 shahdad.lotfi0.00 |
08-25-2016, 06:22 PM | #2713 | |
Rep 10
BTW, I have another problem and I not sure if anyone here is experiencing it too! I have enabled video in motion and mkv files to be able to be read from USB. The problem I have is that after like 5-20 min of playing, the screen goes blank and only the sound is coming, and the only way to get out of this is to completely switch off the car, and wait for about 10 min outside and then get back into the car and replay it. I thought that is because of high resolution of the files, (1080p mkv) or playing from HDD, but after changing the format to a lower resolution and using a USB Key, it didn't seem to resolve the problem. |
08-26-2016, 12:15 AM | #2714 |
Rep 3
Does anyone know what's meaning of those parameters below?
I have F15 2016, coding via esys 3.27.1, PSdZData v.59.2 MAPPING_STANDL_V_L(R)_OUTPUT MAPPING_STANDL_V_L(R)_PART_OF MAPPING_STANDL_V_L(R)_FUNCTION MAPPING_STANDL_V_L(R)_PWM_1_STANDARD MAPPING_STANDL_V_L(R)_PWM_2_REDUCED MAPPING_STANDL_V_L(R)_PWM_3_REAR MAPPING_STANDL_V_L(R)_FIXED_PRM MAPPING_STANDL_V_L(R)_OFF_MODE MAPPING_STANDL_V_L(R)_IGR_RELEVANT MAPPING_STANDL_V_L(R)_DEPENDENCY_FUNC MAPPING_STANDL_V_L(R)_DEPENDENCY_PWM MAPPING_STANDL_V_L(R)_SPARE_OUTPUT MAPPING_STANDL_V_L(R)_SPARE_PWM MAPPING_STANDL_V_L(R)_DIMMED MAPPING_STANDL_V_L(R)_DISABLE_OUTPUT Thanks, |
09-01-2016, 09:09 AM | #2716 |
Rep 40,752
PM sent.
09-02-2016, 10:23 PM | #2717 |
Rep 422
HELP!
For some reason now I can't connect to either of my cars!!
Little history. I coded my I3 a few months back perfectly and has not been into the dealership yet. My X5 was just in for service and installed the MPPK and they updated the software so all my coding went away. Now I try to connect with the same laptop that I had put away in the garage for awhile and the Connect by VIN is grayed out!! I have shut down the car, unplugged the cable many times, restarted my computer, shutoff the wireless but nothing :-( any ideas guys here is a pic of my screen
2023 I4 40 Msport White/red interior 19"Rims
2023 Ix 50 MSport Hraphite Gray.Oyster interios 22" Rims Retired 2020 X7 MSport 40i 2020 I3s Bev |
09-03-2016, 02:45 AM | #2718 | |
Rep 8,364
09-03-2016, 05:37 AM | #2719 | |
Rep 422
I'm getting a connection to the car but the esys cant read the vin :-(
09-03-2016, 02:31 PM | #2720 |
Rep 592
Did you upgrade your Esys version after the MPPK install? If you have not, go ahead and contact ShawnSheridan for the link. As for the connection issue, you might want to turn off your wireless connection and anti-virus software first. That did the trick for me a while back. Good luck!
09-03-2016, 03:06 PM | #2721 | |
Rep 422
09-03-2016, 03:36 PM | #2722 | |
Rep 592
http://f30.bimmerpost.com/forums/sho...696777&page=99 |
09-03-2016, 04:13 PM | #2723 |
Rep 6
Hi guys - i coded everything i wanted about 6 months ago when my x5 50 (just long enough that i've forgotten the steps so have some reading to do...) was new but just got it back from first service and it got wiped. Could someone please provide the link for updated software and be so kind as to let me know what/how to update before i connect to car? Figure I might as well get updated before even trying. Thanks!
09-03-2016, 05:13 PM | #2724 | |
Rep 8,364
