      08-02-2016, 10:36 AM   #1
Keithwand
106
Drives: 22 X5 replaced 16 X5 6/22
Exhaust Solenoid Valve Mod for '16 X5 non M
BMW incorporated a non golf tee mod and I'm trying to figure out how to keep the right side vale open full time.
I started the car cold (in sport mode even) and while the valve was open I unsnapped and pulled the wiring away.
The valve closed anyways!
This unit does not use a hose or arm/ rod assy.
I have searched this forum and googled but everything shows for older cars and the golf tee mod.
Can it be done on 2015/16 X5 3.5i?
      08-02-2016, 11:44 AM   #2
stewy604
stewy604's Avatar
290
You've got a couple options it seems, from a quick Google search:
-Put the car in Sport+, Rev the Engine, Shut the Engine Off, and Unplug the electrical connection to muffler flap
-Go with a Macht Schnell Exhaust Valve Control (EVC) module
The latter seems more common with the F85 guys, although its pricey.
2007 Suzuki GSX-R 750
      08-02-2016, 11:57 AM   #3
Keithwand
106
Unfortunately there is no Sport+ in the regular X5.
I tried to wire the clamp open and then I tried a clamp while the engine was running.
Neither worked.
      08-02-2016, 12:00 PM   #4
Nonopr01
Drives: 2017 BMW M3
there you go:
https://www.ecstuning.com/BMW-F15-X5...nce/ES2999058/
      08-02-2016, 06:10 PM   #5
iconoclast
Self-Deprecating Narcissist
iconoclast's Avatar
7266
where does that connect?
      08-02-2016, 06:40 PM   #6
knepsterd
Drives: 2018 M3 BSM
http://cgprecision.com/cms/images/VSC-2_User_Guide.pdf
This is for M cars but you get the idea
      08-02-2016, 06:44 PM   #7
knepsterd
Drives: 2018 M3 BSM
I'm the Guinea pig just ordered will report before and after next week lol
      08-02-2016, 06:54 PM   #8
knepsterd
Drives: 2018 M3 BSM
http://cgprecision.com/cms/images/st...User_Guide.pdf
Ordered open default and factory automatic when activated via remote fob
      08-02-2016, 08:06 PM   #9
iconoclast
iconoclast's Avatar
7266
ah, sadly 50i does not have any valve.
      08-03-2016, 08:34 PM   #10
Keithwand
106
Any other ideas?
      08-03-2016, 11:05 PM   #11
MarineOh3
MarineOh3's Avatar
Drives: 2012 F30 / 2016 F15
Neither worked.
What is a "regular" X5? Granted I only have about 400 miles on mine and haven't used Sport+ mode yet because I am knee-deep in the break in period, but I am positive I have the Sport+ in my 35d. Just curious if a 35d classifies as a "regular" X5.
2012 328i Sport Line - JB on Coral Red
2016 X5 35d M Sport Line - CBM on Ivory White and Black Dakota
      08-04-2016, 08:14 AM   #12
Keithwand
106
Regular or base not M.
Mine is X line 35i. No Sport + unless I'm not doing it right.
      08-04-2016, 09:17 AM   #13
MarineOh3
MarineOh3's Avatar
So mine is a 35d. I have the M Sport package but don't really know why that would matter. 100% certain it has Sport +
      08-04-2016, 09:19 AM   #14
Nonopr01
Drives: 2017 BMW M3
My 2016 X5 X35i does not have sport plus. It is only available on the M package.
      08-04-2016, 10:54 AM   #15
alphaod
alphaod's Avatar
Sport+ can be coded.
The tranny is the same on all the F15s.
      08-04-2016, 10:56 AM   #16
MarineOh3
MarineOh3's Avatar
Which is why I was surprised that some models don't have sport+ standard. Seems silly to me since it's just a software thing. Sorry for confusing the issue.
      08-04-2016, 04:41 PM   #17
Nonopr01
Drives: 2017 BMW M3
How????
      08-05-2016, 02:29 PM   #18
knepsterd
Drives: 2018 M3 BSM
Impressions
INSTALLED With the valve controller you can choose to open them all the time. Have MPE and it's made a great difference. You don't realize how often the valves are closed in the OEM factory setup regardless of sport or sport plus mode. True they open when you floor it but the noise from 1000-3000rpm is far better with valves forced open.
An additional benefit of an open valve is a much more prolific bark when you lift off the pedal quickly and the pressure dumps. It's really quite loud and puts a a smile on my face. Overrun burble is also louder as in both these situations with the OEM setup the valves would be closed.
If you've spent the money for the MPE, the valve controller will make the most of it.
      08-05-2016, 02:53 PM   #19
knepsterd
Drives: 2018 M3 BSM
Last mod for me might be AR catless DP
      08-06-2016, 05:06 AM   #20
Stinkyxy
Drives: X5
I thought MPE doesn't have a valve?
      08-06-2016, 06:32 AM   #21
knepsterd
Drives: 2018 M3 BSM
OEM Closed sport + mode
I also like the fact I can close at start up if need be early in AM
Neighbors like that
      08-09-2016, 07:50 PM   #22
Keithwand
106
So no simple fix.
