08-18-2016, 11:33 AM | #1 |
Rep 5,730
Drives: '24 iX50; '23 i4 M50
Does This Look Off--M Performance Exhaust Tips?
Just had my 20k service and complained of a fluttering noise at low speed/rpms. Had master tech join me on a test drive in order to duplicate the sound and he heard it.
Just picked up the car and they replaced the MPE and tips, but now after looking at it in the garage, I seem to think the tips are a bit more extended beyond the bumper than before. Is it just me or does this look bad?
'24-I20 iX 50; '23-G26 i4 M50; '22-G82 M4Cx*;20-G05 M50i*; '20-F82 M4CS*; '18-F80 M3CS*; '18-F80 M3CS*; '18-F85 X5M*; '18-G01 X3M40i*; '18-F80 M3ZCP*; '17-F80 M3ZCP*; '15-F15 X5*; '15-F82 M4*; '12-E92 335is*; '11-E70 X5d; '11-E89 Z435is*;'09-E89 Z435i*; '08-E92 335i*; '06-E90 330i*; '05-E83 X3*; '04-E83 X3*; '03-E46 325Ci* *retired |
08-18-2016, 11:37 AM | #2 |
Rep 5,730
Here's some what of a pic from my previous MPE right after delivery (hard to tell however)
zachzay8.00 |
08-19-2016, 08:11 AM | #6 | |
Rep 5,730
BTW, you've been down this road as well with your previous X and this fluttering noise. Replacing the MPE didn't solve the problem. Maybe I should get an X5M also!
08-19-2016, 08:43 AM | #7 |
Rep 8,809
In my case they tried to do the same.
Replaced my full exhaust with a stock one the dealer had. No change Replaced the turbo with a brand new one. No change Removed the belts to eliminate any accessories causing it. No change Removed my transmission and ran the engine. No change Removed the MPPK software. No change Removed the oil pan to see if there are any signs of rod bearing failure. No sign Checked oil filter for metal shavings. No sign All in all my process took 5-6 weeks before i told them enough is enough. You can keep the car because i don't want it back. It was sitting on the lift for with half the drivetrain just hanging off the car for way too long. Keep me posted on what happens with yours. I think at the end the dealer replaced the entire engine and sent it back to BMWNA to auction. Alan
08-19-2016, 02:43 PM | #8 | |
Rep 5,730
Just reread my previous post and I didn't mean to say replacing the MPE didn't solve the problem for me--I was referring to your situation. This is my wife's car, and unless it doesn't start, she doesn't give a rat's...I'll need to wait until the new MPE breaks in a bit to see if I still hear the noise.
08-19-2016, 05:24 PM | #10 | |
Rep 5,730
08-22-2016, 10:01 AM | #12 |
Rep 1,547
^ Dang...that's some flutter. What was the root cause, any idea?
08-22-2016, 10:15 PM | #14 |
Rep 8,809
Mine was more a metallic ticking sound from idle to about 3K rpm only. You notice it way more if you are driving next to a wall because it echoes off it. Didn't matter if i was in sport or comfort mode, hard or soft on the throttle. It just starting ticking out of the blue and the dealer never figured it out. After the trade assist they ended up swapping in a new motor.
Scary that this is actually becoming more common with N55 X5's as of late. Alan
08-23-2016, 10:27 PM | #15 |
1150
Rep 2,426
I guess I'm glad I've got a N63 then... but then again we have our slew of problems.
OP, that definitely looks like it sticks out more than it should. |
08-26-2016, 05:27 PM | #16 |
Rep 5,730
My "fluttering" noise appears to have been resolved with the new MPE. Borrowed it from my wife this morning and I could not duplicate the noise.
And I no longer find the exhaust tips to be odd looking.
08-26-2016, 10:54 PM | #17 | |
Rep 51
08-26-2016, 10:57 PM | #18 | |
Rep 51
08-26-2016, 10:58 PM | #19 | |
Rep 51
08-27-2016, 10:47 PM | #20 |
Rep 8,809
Same here. I brought it in thinking it was a simple wastegate rattle fix or something needed to be tighten but it turned into a 6 week ordeal for me.
