      03-24-2018, 08:56 PM   #4071
shawnsheridan
shawnsheridan's Avatar
Originally Posted by fromkrypton View Post
Possible to get the latest coding software?
Thanks in advance!
PM sent.
2018 F06 Alpina B6 650ix GC; Space Grey; Vermillion Red Nappa Leather; Executive; B&O; Driving Assistant
2017 F15 X5 xDrive50i MSport; Glacier Silver Metallic; Black Dakota Leather; Executive; B&O; Driving Assistant; RSE
      03-25-2018, 09:21 AM   #4072
fromkrypton
Drives: 2015 X5 35d
2015 BMW X5 35d  [0.00]
Thanks in advance!
PM sent.
Thank you very much!!!
      03-25-2018, 01:21 PM   #4073
fromkrypton
Drives: 2015 X5 35d
So to add enhanced Bluetooth it would look like this?
6AR, 6NS, 6WB,
Thanks!
      03-25-2018, 06:00 PM   #4074
HZX540e
HZX540e's Avatar
Drives: 2021 X5MC
sequential turn signals
Has anyone figured out how to code this feature (sequential turn signals)
      03-25-2018, 07:27 PM   #4075
shawnsheridan
6AR, 6NS, 6WB,
Thanks!
Yes.
      03-26-2018, 09:56 AM   #4076
fromkrypton
Drives: 2015 X5 35d
Yes.
Super easy to do! Now I get text messages on my idrive! I can't believe how BMW Canada charges for this small amount of coding.
      03-26-2018, 10:45 AM   #4077
shawnsheridan
      03-26-2018, 11:19 AM   #4078
fromkrypton
Drives: 2015 X5 35d
I did get worried when I wrote it to the car it was almost instantaneous. I didn't think it had worked but it really was like magic.
Thanks for the help guys!
      03-27-2018, 08:24 PM   #4079
drowningman
Drives: '11 1M '19 i3s '19 F60
coding software
Hi Shawn,
Can you send me the latest esys and launcher? had to replace a headlight on the f15 and need to recode it.
Cheers and Thanks!
      03-27-2018, 09:11 PM   #4080
shawnsheridan
Originally Posted by drowningman View Post
Hi Shawn,
Cheers and Thanks!
PM sent.
      03-27-2018, 11:32 PM   #4081
kry226
Hi folks- great thread. I really appreciate all the contributors/contributions.
Quick question...I'm going to be VO coding my 2018 F15 for heated steering wheel retrofit when it arrives in April or early May. Which ECUs do I need to code once I've added the 248 to the VO? Thanks in advance!
P.S. I'll be swapping the wheel and switch too. I know coding alone won't get me a warm steering wheel.
2018 X5 xDrive35i M-Sport - Traded
2013 X1 xDrive35i - Sold
1986 320i - Sold
      03-28-2018, 01:43 PM   #4082
joyride
Drives: X5 M-Sport
Quick question - I got the Esys cable, and followed the instructions provided. With the VM provided in the instructions. Seeing everyone ask/receive for the latest software, is that something I should/could do as well? Or should I just leave it as is for some reason. Thanks in advance.
      03-28-2018, 10:07 PM   #4083
Almaretto
Almaretto's Avatar
2374
Drives: Test Vehicles
You need PSdZ > vehicle I-Step. If you are not getting reading errors, then no reason to update.
      03-29-2018, 10:32 AM   #4084
pits200
Drives: 09 335i X-Drive Black Sapphire
I've been able to do FDL coding with no problem. Trying to update my FA/VO today to add SBRE for msport brakes but when I calculate FP, I only get blank folders on the right with number references only. When I look in DATA\FP folder, I don't see anything within there.
I've downloaded E-sys correctly and PSzdata lite and as state can do FDL coding, any reason why I can't see FPs?
thanks,
      03-29-2018, 10:44 AM   #4085
shawnsheridan
thanks,
Ignore it. FP (Vehicle Profile) is unimportant. Calculate FP, and if no errors, Save FA and proceed with coding.
pits200547.50
      03-29-2018, 11:21 AM   #4086
pits200
One last question, so when I try adding in SBRE, do I add that as a sibling of K235. When I right-click on HO-Wort, I can't edit, I can only choose "new", do I simply type in SBRE and that's it?
Thanks again
      03-29-2018, 11:23 AM   #4087
shawnsheridan
Thanks again
Yes, Right-Click => New => SBRE, then both HO-Wort will be present.
pits200547.50
      03-29-2018, 01:15 PM   #4088
pits200
I feel helpless.
I wrote the new FA, went back to coding, FA showed new SBRE, I read ECU, and it showed DSC2 when people were stating it should show DSC. I activated FA and coded DSC2. Drove the car around and to me the brakes feel the same.
I'm not sure if DSC2 already existed prior to adding SBRE. Anymore input is appreciated.
Edit: Update
I guess DSC2 is correct, I now see that
my front rotor size is FN AL 42 /36/395
Rear was set to FN AL 42 /24/385, since I didn't change the rear, I changed those back to FN AL 44/24/345
      03-29-2018, 07:21 PM   #4089
Chapultepec
Drives: X5 (Euro) X4 (US)
Retrofit TPMS to X5 5/2014
My retrofitted TPMS' are not working. Retrofitted TPMS to my 5/2014 X5 35xi Euro. Sensors are 6855539. Added option 2VB to FA and VO coded HU_NBT and KOMBI. Could not find any relevant RDC/RPA coding in BDC nor DSC. iDrive screen looks like on photo. All TPMS' seem to be connected, but no readings. Anyone has an idea how this could work, what did I do wrong?
      03-29-2018, 11:22 PM   #4090
kry226
OK, radio silence. Let me ask a different way... if I add 248 to the VO, I can code the new VO to every ECU and that will ensure heated steering wheel functionality without negative effects, correct?
Thanks again.
1986 320i - Sold
      03-30-2018, 01:16 AM   #4091
Almaretto
Almaretto's Avatar
2374
Thanks again.
No negative effects if you are using external charger and clear errors with external transmitter.
You can use TM NCD / CAFD tool to give you an idea of which ECU's to code.
      03-30-2018, 05:05 AM   #4092
kry226
OK, thanks! Now by external transmitter, you mean E-Sys Transmitter function?
I.E., Click "External Applications" in the left menu.
Click "External Application"
Double-click "Transmitter"
Scroll to the bottom and double-click "... Clear all DTCs ..."
Correct? Thanks again.
P.S. I know the newbie questions get tiresome but thanks for your patience.
1986 320i - Sold
