09-01-2023, 02:28 PM | #1 |
Specialist
1310
Rep 2,708
Style 611 Orbit Grey 20x10/10.5 Winter Snow Tires Pirelli 285/40/20
These had about 4 weeks on the car MAX and not daily driven. The tires have basically all their tread left. I found a sweet deal on 21" snow tires so I ended up using those instead. I am not shipping these anywhere so please don't ask. I live in lower Westchester County NY. 36112284654 x2 36112284655 x2 TPMS Sensors x4 SCORPION™ WINTER 285/40R20 108V XL BMW x4
09-03-2023, 07:54 AM | #3 |
NEED MORE POWER!!!
38
Rep 43
Drives: 2016 X5M
What model did these come off of? I have a M and rear hubs are different from what I have read.
09-03-2023, 04:24 PM | #4 | |
Rep 7,505
Only the E70 X5M, E71 X6 & E71 X6M have the spit hub where the front is 74.1mm and the rear is 72.56mm. The regular E70 X5, F15 X5, F16 X6, F85 X5M, and F86 X6M have the same 74.1mm hub in the front & rear. The E53 X5 has a 72.56mm hub front & rear All of the above E & F chassis X5/X6 models also have a 5x120mm wheel bolt pattern. The G05 X5 & G06 X6 has a 66.6mm hub front & rear and the wheel bolt pattern has also changed to 5x112mm I’m not certain (correct me if Im wrong)…but the G95/G96 X5M/X6M probably has the same wheel hub specs & wheel bolt pattern as the G05 X5 & G06 X6.
NYBulldog1310.00 |
09-03-2023, 05:30 PM | #5 | |
NEED MORE POWER!!!
38
Rep 43
Drives: 2016 X5M
Thank you for that information!! I have the F85. This is a big help. |
09-05-2023, 09:24 AM | #6 | |
Specialist
1310
Rep 2,708
09-05-2023, 09:26 AM | #7 |
Specialist
1310
Rep 2,708
They are off a F85 2018 X5M. :
Sunpro201038.00 |
