06-09-2021, 08:31 PM | #1 |
Rep 10,305
3G Shutdown: Parts, Procedures, and Shops willing to try the retrofit
Starting a new dedicated thread for owners of F15 vehicles that cannot receive a technology upgrade from BMW but want to find a way to do it.
Goals of the effort - identify: 1. All required parts 2. Installation procedures, including wiring 3. ConnectedDrive configuration and activation options (might have to visit the dealer ...) 4. Shops willing to perform the retrofit I will be visiting a local shop in OC (SoCal) that has a lot of experience with BMW vehicles. Will share an update. UPDATE: June 14, 2021. I spoke to a very helpful parts manager at a BMW dealer. The solution described below will produce 4G ATM module with your vehicle's VIN. It does not use a donor vehicle with an active subscription. While active donor vehicle approach can work initially, BMW can deactivate the IMEI associated with the donor vehicle for many reasons. Here are the steps: 1. Call your local BMW dealer parts department, provide VIN, and ask them for PN 84 10 68 36 777 - or US ATM 4G module 2. The parts system should confirm that this part number can be ordered for your VIN. This is a KEY requirement. BMW dealer will order a part only if the system indicates it can be ordered for your VIN. This has been confirmed for my vehicle - 2015 BMW X5 3. Order the part. It will arrive with your VIN already provisioned. The most difficult part is now behind at approximately $700. 4. Order and install NBT Evo head unit with 18-03 firmware from https://www.codemybimmer.ca/product/...t-2016-models/. Codemybimmer ships NBT Evo head units with 18-03 firmware. 5. Order BMW F SERIES NBT EVO ID5/6 ATM RETROFIT WIRING LOOM PLUG & PLAY + GIFT(FSC Pack) https://www.ebay.com/itm/16333260576...oAAOSwaG1b0DxV. The wiring instructions are in the item description. 6. Install new ATM and take a photo of the label with IMEI number. 7. Connect the wires 8. Call BMW ConnectedDrive and inform them that the ATM module has been replaced and share the IMEI and any other information That should be it. I haven't done this yet but will schedule time to prepare and order all parts. Last edited by cfm56d7b; 06-14-2021 at 08:24 PM.. |
06-09-2021, 10:56 PM | #2 |
Rep 2,520
Parts list is pretty much here:
https://f15.bimmerpost.com/forums/sh....php?t=1593428 As far as I understand hardest part is getting the ATM module for your car. |
cfm56d7b5922.50 |
06-10-2021, 12:42 AM | #3 | |
Rep 10,305
06-10-2021, 10:17 AM | #5 |
Rep 10,305
06-10-2021, 11:50 AM | #6 | |
Rep 552
I have not heard of anyone being successful at getting a retrofitted ATM to their VIN via a dealership. |
06-10-2021, 12:39 PM | #7 |
Rep 2,520
Nothing really, but they won't do it. Your experience might be different but dealership gets parts based on VIN number and in case of ATM unit it is the key to the proper functioning system but 2013-2016 F15 has 3G module which is no longer works and never had an ATM unit with 4G support per original catalog. Same thing people seen with knee pads when dealer won't order you a pair unless you give them VIN from X6. So you can buy a used ATM module from North America car and try to make it work (like the OP from the thread I mentioned), but I doubt you will be able to get an ATM unit for your specific VIN from the dealership.
06-10-2021, 01:13 PM | #9 | |
Rep 10,305
Thoughts? |
06-11-2021, 07:29 AM | #10 | ||
Rep 552
Like CatalinP said, then add that VIN to your subscription so you keep paying for the services. |
06-11-2021, 11:14 AM | #11 |
Rep 10,305
After researching ATM modules, the ATM module in 2017/2018 F15 X5 vehicles is also used in other BMW vehicles, including F3x.
Does anyone know if an ATM module from a late model F3X and active Connected Drive subscription can be fitted in BMW X5? Does Connected Drive server care that the donor ATM module came from F3x? |
06-11-2021, 09:17 PM | #13 |
Rep 10,305
Ddayan97 was able to get his local dealer to code an existing VIN in a new ATM module ($600).
https://f30.bimmerpost.com/forums/sh...1670258&page=2 Post#24 If the dealer can in fact update a new ATM module with the original VIN (although ATM module was not associated with the original VIN), then a solution path might exist: 1. Install NBT Evo head unit with original VIN already flashed. 2. Buy a new ATM module 3. Ask the dealer to code the original VIN in the ATM module (the above post also references DCSnet service bulletin how to do it) 4. Ask the dealer to contact BMW Connected Drive and update VIN / IMEI combination because the new ATM module has a different IMEI. Or - call Connected Drive customer service and explain that the module was replaced and provide new IMEI number. I spoke to BMW Connected Drive and was assured that as long the vehicle can initiate / receive 4G signal the services will remain active and can be renewed. Essentially, if the dealer retrofits 4G signal on a vehicle which could be retrofitted, the result would be the same. I asked my local dealer to confirm if the original VIN can be coded to a new ATM module. |
06-12-2021, 06:03 PM | #14 | |
Rep 552
See this thread too.. F15 NBT Evo Retrofit https://f15.bimmerpost.com/forums/sh....php?t=1593428 Retrofitting everything is definitely posible, they just don't want us doing it. But my personal though on all this is, can a dealership really match a new IMEI to your VIN via ATM? I thought that was done when the new ATM is ordered, that is why they order it off of your VIN. So I assume it is already programmed to your VIN prior to shipping 🤷🏽 (just me thinking out loud here). |
06-14-2021, 10:45 PM | #16 |
Rep 2,520
So this would cost $2000+ for the retrofit. Not sure if I am willing to spend this much money on my 7 years old X5.
Maverik2594146.00 |
06-17-2021, 08:28 AM | #19 | ||
Rep 26
$2000 outlay v c. $30000 difference between trade-in and new car similarly equipped is a no-brainer (for me) |
06-17-2021, 08:43 AM | #20 | |
Rep 26
What's your timeline in doing this? Who did you speak to at your dealership (what role)? Reason I ask is that the service manager did t even know what o was talking about - I feel like CD and the tech is almost like finding the right person in an IT department... |
06-17-2021, 10:44 AM | #21 |
Rep 2,520
06-17-2021, 11:10 AM | #22 | |
Rep 10,305
If the goal is to retain OEM SOS and teleservices, the only option is to order a newer ATM module, while BMW parts system shows that this module is still valid for your vehicle's VIN. Once the module has been purchased (it will be provisioned with your vehicle's VIN), then you can purchase NBT Evo head unit, wiring loom, and install all three components. It's best to find a qualified shop in the area. I am also working with an engineer who plans to offer a complete package: - NBT Evo head unit with original VIN flashed - Wire loom - Working ATM with original VIN (the more complex effort since a new ATM has to be purchased) - All components will be bench tested together including verifying that Connected Drive services will work. This a major plus. I will have to supply a temporary userid / password combination This effort is still in progress. |
4
Tags |
3g shutdown |
