08-27-2015, 09:23 AM | #1 |
26
Rep 365
Does X5M have a weak a/c?
I live in TX - that hasn't changed, I know it gets hot around here. With my 550, M5 and M6, never had a problem with cooling. With My x5m, seems I have the thing set to max for a better part of the afternoon.
Now, I understand that the cabin is larger and the outer surface larger BUT, did BMW accommodate for this? The air coming out of the vents is cool but not cold. It also doesn't blow very 'hard'. The rear vents barely blow at all. True that?
2015 ///X5M
2014 ///M6 (traded) 2014 ///M5 (traded) 2011 550i (traded) |
08-27-2015, 10:08 AM | #3 |
Rep 492
Agreed -- although we had the warmest Southern European summer in a while, I share the "weak A/C" deficiency, never experienced in my former 2011 X5 50i.
One difference and probable cause is the unavailability of the option 358 in the new F85 X5 M, the "infrared shielding" windscreen; it's on the option list but it is practically unavailable because of the rear mirror mounted front looking camera supporting the safety features standard (meaning compulsory) on the X5 M sold here. On sunny summer days I distinctly recall the leather covered dashboard never becoming so hot in the former X5, so the A/C in the new X5 M has a vastly higher thermal load inside the car to work against. I'm afraid we're stuck with it -- at least, MAX A/C is noisy but cools more than enough. |
08-27-2015, 10:40 AM | #4 |
Rep 2,773
Drives: F95 X5MC
My A/C seems to work fine, but I agree, the ventilated seats don't help much when it's very hot.
2020 F95 X5///M Competition CarBahn Autoworks Stage 1 | 2023 Lamborghini Huracan Tecnica
08-27-2015, 12:19 PM | #5 |
Rep 64
Agree!
In Southern California with temperature sometime reaches over 100+ degree, the AC just simply can not handle this hot climate. Also the ventilated seats don't help much either. |
08-27-2015, 04:58 PM | #6 |
Rep 137
It's not just the X5M, it's a common problem with the F15 X5's in general. I believe it's either a design or a software tuning issue. I've asked my dealer and they said BMW is aware of this and is working on a fix. Who knows what means.
08-27-2015, 10:43 PM | #7 |
Rep 44
I am in Florida and it's hot here as well...
The AC on my new 2016 X5M is very good, but ventilated seats as others have mentioned are not that powerful. As a comparison the ventilated seats on my 2015 911 GTS work a lot better.
2018 M5
2018 RR Dawn 2014 Porsche GT3 |
08-27-2015, 11:29 PM | #8 |
Rep 132
08-28-2015, 10:35 AM | #9 |
Dinan-M
291
Rep 618
HOT In San Antonio, TX
MY 2015 X5M AC is the worst I have seen in a BMW Vehicle. I have driven them for about 30 years now. The best AC is in my 2006 M5. Do anyone know if BMW is aware of this issue? Good Thread.
08-28-2015, 12:28 PM | #10 |
Rep 729
This may sound stupid, and you all may have done this already, but those who are complaining about the A/C, where do you have the colored thumbwheels on the center dash set? You know, the ones that are red and blue on either side of the hazard button? On extremely hot days, set them to all blue, both of them. Even the slightest movement towards the middle, or the red zone makes a large difference in the interior temperature of the vehicle. These same wheels are available in the rear seating area, too. In the summer, I keep them to all blue, in the winter, I set them to the middle between red and blue.
We don't get quite the extreme of temperatures on cape cod that you all down south get, but we have had a few days in the mid-90s with dew points well above 70, and I've never had an issue getting my X5 M comfy on those days, so long as those thumbwheels are set to "blue." |
08-28-2015, 01:49 PM | #11 |
Rep 64
Today's temperature at LA is 100 plus, some locations reach up to 106 degree and higher.
I move all vents thumbwheels to BLUE in my X6M, the AC still can not cool down the cabin temperature after running 5 mins on the road. BMW AC system really disappoints me. |
08-28-2015, 03:14 PM | #12 | |
Rep 729
The ventilated seats in my E70 X5 with multicontour seats were far superior to the piddly little airflow that comes from the fancy seats in my X5 M. The fans were whisper quiet in the E70, too. The ones in the F85 sound like they are going to take off or something. |
08-28-2015, 03:40 PM | #13 |
Rep 3,198
Not sure if this is the same for you F85 folks, but on my E70 X5M I had to actually go into the climate options. There will be a diagram of the seat with a cold to warm dial on the side. I found setting that to max cold is what changed the AC the most. All the physical buttons did nothing compared to doing it in idrive.
08-28-2015, 09:02 PM | #15 | |
Rep 222
08-28-2015, 09:03 PM | #16 | |
Rep 222
08-30-2015, 08:49 AM | #19 | |
26
Rep 365
2015 ///X5M
09-02-2015, 10:07 AM | #20 |
Rep 13
I'm in Qatar where its around 43-44C the A/C is weak but today i noticed something i went into the climate section in the iDrive and unticked the rear climate option 2 mins later the A/C was so much better.
Maybe you guys should give it a try |
09-02-2015, 10:52 AM | #21 | |
26
Rep 365
2015 ///X5M
