07-22-2017, 09:56 AM | #221 | |||
Rep 18,773
If it is custom cut, you shouldn't take it if the offset is not what you like.
Email:sales@rgsport.com | IG:RGSport_USA | Web:RGSportShop.com PM for Everyday DEALS!! MSS iSweep RaceChip Sterckenn AutoTecknic Akrapovic Vossen Wheels Eventuri Active Autowerke KW H&R Ohlins Remus and more... |
07-23-2017, 02:33 PM | #222 |
Rep 428
Drives: 2015 X5 35d
07-23-2017, 02:54 PM | #223 |
Rep 32
07-23-2017, 03:14 PM | #224 | |
Rep 18,773
I don't understand by just "Yes" answer. Please be more clear.
07-23-2017, 03:16 PM | #225 | |
Rep 428
Drives: 2015 X5 35d
07-23-2017, 03:20 PM | #226 | ||
Rep 18,773
07-24-2017, 12:29 AM | #227 | |
Rep 32
07-24-2017, 11:37 AM | #228 |
Rep 18,773
Hmm, which style of wheel is that? I couldn't figure out which OEM 20x9.5 wheels that you are using.
Post the picture if you don't know which style.
08-27-2017, 10:55 AM | #229 |
Rep 180
Trying to decipher the front xDrive limitations. Does it apply on a 2014? What are my options? Thinking 15/20 based on some pics I've seen.
08-27-2017, 11:58 AM | #230 |
Rep 18,773
PM me the last 7 of your VIN.
09-02-2017, 08:43 PM | #232 |
Rep 18,773
Yes, you can do 20 front, just be aware that it will looks funny.
09-02-2017, 10:10 PM | #233 |
Rep 21
Any need for longer wheel bolts, or are the stock ones long enough to cover the increased widths? I added spacers on my 911 and had to upgrade the lug bolts. Just curious as this 15/20 set up looks like something I'd like to do...
09-03-2017, 12:46 AM | #234 | |
Rep 18,773
You can't do 15/20 on your 2015 X5, only 5/15 or anything thicker than 15mm on the from.
G8rdmd10.00 |
09-03-2017, 04:14 PM | #235 | ||
Rep 21
11-05-2017, 09:32 AM | #236 |
Rep 749
Drives: 2016 528i Executive Edition
I have a 2014 X5 35d x drive.
So to clarify, I'd I have a pre November 2014 production date, I should be able to go 15mm front and 20mm rear. But if I have a post November 2014 production date then I can only go 5mm front and for rears can still do 20, but 15mm might be but more even in appearance? How do I find out when my production date was? Also I've also been searching for spacers for our f series x5. But havnt cone across where sells them. Will our f15 fit all spacers for any f series car? Thanks! |
11-05-2017, 09:54 AM | #237 | |
Rep 18,773
The spacer will only fit F chassis X5/X6/X5M/X6M and some E chassis X5/X6/X5M/X6M.
11-05-2017, 01:19 PM | #238 |
Rep 714
Drives: BMW X5 M Sport - G05
So that I dont have to search through 11 pages, what changed between 14 and 15 that calls for different spacers? I dont have them on my fronts, but just curious.
11-05-2017, 01:24 PM | #239 |
Rep 749
11-05-2017, 01:24 PM | #240 |
Rep 18,773
The front hub height or lip is taller or longer.
11-22-2017, 04:21 AM | #241 | |
Rep 156
sorry for posting on the wrong thread. My car is an older X6 E71, does the 15mm front spacer problem affects my car as well? or just the newer ones? I just recently purchased H&R wheel spacers. 15mm front (#3075740) and 20mm rear (#4075725). also noticed that during installation, when placed on the hub, the front spacers move freely by hand, easy to mount on to the hub (you can spin it by hand). However, the rears are somewhat tight, I did remove the rust from the hub bore using wire brush. (It can also be moved by hand with some force, this was after I applied some hi temp grease on the hub). but still, it is a tighter fit compared to the fronts. Both of my rear hubs are like this. I was wondering if my hub bore was very slightly bigger for some reason or the bore of the wheels spacer was slightly smaller. Front Hub size of X6 is 74.1 and Rear is 72.5 I'm just kinda concerned that during driving, the hub of the car might expand due to heat and might affect the durability of the spacer. Last edited by bmwstve; 11-22-2017 at 04:58 AM.. |
11-22-2017, 07:51 AM | #242 | ||
Rep 18,773
