10-02-2017, 10:35 AM | #420 |
Rep 1,011
you don't use a cable when using the bimmercode app. it uses a dongle plugged into your OBD and you connect via device wirelessly to it's network (VLINK typically) to communicate with vehicle and code it via the bimmercode app.
nyalpine907439.00 |
10-02-2017, 11:03 AM | #421 |
Rep 3,625
I meant by using the E-Sys software.
10-02-2017, 12:47 PM | #422 |
Rep 666
I have esys 3.26.1 installed on 12/2014 and my pszdata is from the same timeframe. Would I have to go get new versions or can I use what I have installed on the machine? (my car's software isn't the same as it was then)
10-02-2017, 01:01 PM | #423 | |
Rep 666
Now all I have left is getting my door chime back. Hmmm... |
10-03-2017, 08:50 AM | #424 |
Rep 214
an update on things I recently learned regarding the use of this app - disclaimer, I've not contacted the developer to verify my findings
yesterday I had my 535 worked on, and in the course of the work (I knew this was coming), they had to recode my head unit. Knowing I'd need to redo the mods I had in place, I pulled out my trusty OBD adapter. once connected - no backups. No biggie, took all of 15 minutes to redo what I needed, but here is what I suspect a. When the Bimmercode app was updated, the backups I did have, became lost. FWIW, I've not yet updated to IOS 11 (work phone, the IT geeks have to prove it all works) b. Going forward, three lessons learned I will adopt in the future b1 - When I see that the Bimmercode app has an update, I'm not going to just automatically hit "update" b2 - When I do update the app, I will immediately do a code so as to have a current backup b3 - anytime I take either of my cars in, I'll make sure I've got current backups in place again, no real biggie, 15 minutes while dinner was being cooked so no real harm
2016 X5 35i Xdrive M Sport; Space Gray Metallic/Mocha Dakota
2014 535i Xdrive luxury line; Black Sapphire Metallic/Black Dakota |
OFFWHITEX5325.50 |
10-07-2017, 09:34 PM | #425 |
Rep 23
Question, I used Bimmercode to change my turn signals soft flash from 3 - 5 flashes but I can't get it to stay even though it codes successfully. Any Ideas?
Secondly, I added my turn signals to the HUD; for example I will make right turn and right blinker flashes in HUD but you can see faint outline of the left blinker... Is there a way to remove this? |
10-08-2017, 09:13 AM | #426 |
2020 Mineral White 30d MSport
524
Rep 2,146
Drives: 2020 Mineral White 30d MSport
Same here, I had it factory coded but I just made it to fold the mirrors after leaving my hand on the handle for about 1 extra second instead of 4-5 seconds before coding, and immediate if I fold them via keyfob
10-11-2017, 04:53 PM | #429 |
16
Rep 348
Drives: M6 Comp Gran Coupe & X5 MSport
Hi Guys, what's the difference between VGate 2 & 3 ?
Will this one in the link below work fine ? https://www.amazon.co.uk/Vgate-Diagn.../dp/B01C5KRZUU Thanks |
10-11-2017, 04:58 PM | #430 | |
kr0m3assass1n
1094
Rep 863
Drives: 22 X7 M50i
But that?s just my 0.02£. Good luck! |
10-11-2017, 06:23 PM | #431 | |
Rep 3,742
The software developer recommends vGate2 on the BimmerCode website. |
10-11-2017, 06:27 PM | #432 | ||
Rep 214
10-12-2017, 07:03 AM | #433 |
16
Rep 348
thanks guys V2 it is then.
10-12-2017, 09:20 PM | #434 | |
Rep 3
10-12-2017, 09:37 PM | #435 |
Rep 3
10-12-2017, 11:01 PM | #436 |
Rep 3
10-13-2017, 06:59 AM | #437 |
Rep 11,850
Drives: MY24 G01 AW Msport
last night i install the app and purchase the V2, how does it work?
UPDATE: Do i need to purchase the option UNLOCK CODING $34.99 ? Last edited by nyalpine90; 10-13-2017 at 01:14 PM.. |
10-14-2017, 12:21 AM | #439 |
Rep 11,850
10-14-2017, 07:06 PM | #440 |
Rep 11,850
What is small cd that came with?
Is it setup cd? |
