06-21-2016, 07:54 AM | #45 |
Self-Deprecating Narcissist
7266
Rep 6,561
was there an issue with the rear rotors bolting up? i have read on some threads that the hole for the set screw does not line up if you try to install x5m drilled rotors.
06-21-2016, 08:10 AM | #46 |
Rep 8,821
^^ that is correct. I only went F85 rotors up front and kept the rotors that came with the MPBK. For the F85 rear rotors you need to have a new hole drilled for it to work.
Up front the F85 rotors needs a new screw to bolt the rotor to the hub. The stock screw off my F15 didn't work for the F85. Its a $5 part so simple fix. Alan
06-21-2016, 09:17 AM | #47 |
Rep 1,547
^^ I'll be doing the same as Alan. The kit and F85 rotors have arrived at my local dealer, just need to head down and pick them up. I opted for the lower dust Carbotech pads, dealing with Mike down there was a breeze.
06-21-2016, 09:35 AM | #48 |
Rep 8,821
Smart having it shipped to the dealer. I had my MPBK shipped to my aunts house and I was surprised that it came on a wood pallet in a box that was over 150lbs. It was a fun morning heading over there before work dismantling the box one by one because there was no other way of me getting it all into the house and i couldn't leave it sitting in the driveway like that.
06-21-2016, 02:38 PM | #49 | |
7266
Rep 6,561
06-21-2016, 02:51 PM | #50 |
Rep 8,821
From my understanding the only performance difference between the rear rotors is the ability to dissipate heat better due to the cross drilled design. I wouldn't expect any other difference. Dimension wise they are exact. I didn't have any issues running my setup at all. Once coded they feel absolutely amazing.
Alan
06-21-2016, 03:52 PM | #51 |
7266
Rep 6,561
what if one does not use the set screw? will there be issues once bolted up with calipers and wheels?
06-21-2016, 04:14 PM | #52 |
Rep 8,821
From what my mechanic told me it doesn't matter if I use the screw or not since the wheels/lug bolts are basically locking the rotor in place anyway. Not sure if the same applies to the rear since the handbrake mechanism is in there.
06-22-2016, 06:45 AM | #53 | |
Rep 18,721
06-22-2016, 07:02 AM | #54 |
7266
Rep 6,561
thank you!
06-23-2016, 09:36 AM | #55 |
Rep 1,547
I'll be installing my setup (mirrors Allan's - except I opted for Carbotech pads) over the next few weeks, just trying to carve out the time. I'll post up my feedback once I do.
09-12-2018, 10:54 PM | #56 | |
N00B
94
Rep 210
The owls are not what they seem!
09-13-2018, 12:18 AM | #57 | ||
Rep 7,160
09-13-2018, 04:35 AM | #58 | |
Rep 426
-Thank you |
09-13-2018, 08:29 AM | #59 | |
Freude am Fahren.
835
Rep 1,287
Drives: F15 X5 xDrive35i
Though it doesn't mean that Carly can do MPBK coding
Freude am Fahren.
09-13-2018, 09:49 AM | #60 | ||
Rep 7,160
09-13-2018, 11:03 AM | #62 |
7266
Rep 6,561
Dealer will not do it unless hardware is present to support it however it is possible to code without the upgrade installed. It results in a minor adjustment in stiffness of the pedal but nothing worth bothering with. If you do the opposite and install and not code for the additional brake booster involvement you get a pedal that basically sinks to the floor before biting and slowing down the vehicle.
09-13-2018, 12:57 PM | #63 | |
N00B
94
Rep 210
09-13-2018, 02:42 PM | #64 | ||
Rep 7,160
09-13-2018, 04:48 PM | #65 | |||
N00B
94
Rep 210
09-13-2018, 09:54 PM | #66 | ||||
Rep 7,160
