      01-04-2016, 11:08 AM   #1
Stang0811
Drives: 2015 BMW X5 MSport Trim
Tools for switching out wheels
Happy New Year everyone
Just wanted to know what tools everyone is using to switch out their wheels - any recommendation would be appreciated
Thanks
      01-04-2016, 11:16 AM   #2
Doanster
Doanster's Avatar
627
Outside of the usual quality jack and stands, a jack pad adapter ensures easy lifting and no damage to the plastic jack points. I lucked out and the adapter I use for my Merc fits the X5 as well. Burger Motorsports sells a BMW-specific unit.
Don't forget the torque wrench naturally. If you want to save even more time, get a cordless impact wrench. I use a Dewalt Li Ion unit.
      01-04-2016, 11:24 AM   #3
Alan l.
Alan l.'s Avatar
5484
I use one of these to speed up the process. After breaking the lugs loose i use this to remove them. I use the same when reinstalling the lugs but do a final torque down with my torque wrench. This is one of the tools i use the most when working on my car from 10mm nuts to wheel lugs. I have an adapter for it so it can take 1/2" sockets as well as 1/4's.
http://www.amazon.com/Bosch-PS41-2A-...+impact+wrench
Alan
      01-04-2016, 12:18 PM   #4
Doanster
Doanster's Avatar
627
For extra reach as well as wheel protection from scuffs, I use this set from Schwaben.
https://www.ecstuning.com/News/Schwa...ets/ES2221243/
      01-04-2016, 01:09 PM   #5
Roundown
Drives: BMW
If you're using an impact driver to speed up the process, I've found these to be useful. They break torque at 75lbs (for you to finish the rest with a hand torque wrench).
https://www.ecstuning.com/ES9021/
The Schwaben torque-limiting socket set prevents over-tightening of wheel bolts and lug nuts. Attach them to your ½-inch breaker bar or impact gun and tighten the wheel bolts or lugs until the socket stops tightening at 74 ft-lb (100 Nm). Then final-tighten the wheel fasteners to the recommended specification using a torque wrench.
Handsome sockets are shop tough, plated to resist corrosion, and color-coded for fast identification. Set takes up less room in your tool box than conventional torque sticks, and comes in a handy blow-molded case for portability and easy organization.
Set includes: 17, 19, and 21 mm six-point impact sockets to fit most metric wheel bolt heads and lug nuts.
      01-04-2016, 01:20 PM   #6
stewy604
stewy604's Avatar
290
Those Schwaben sockets are nice, very slick. I've gone the cheap way and just wrapped my socket with tape (hasn't let me down yet). I also use a set of alignment rods when installing the wheels, makes the process a heck of a lot easier.
Similar to these from Burger:
2007 Suzuki GSX-R 750
      01-04-2016, 05:51 PM   #7
Doanster
Doanster's Avatar
627
Agreed on both fronts. I've always just used black duct tape on my socket, but when I got the cordless impact wrench, the std socket was too shallow and the battery pack would end up smacking the wheel if I wasn't careful. The extra length of the Schwaben set alleviated that. The plastic sleeves were a bonus.
As for the wheel hanger, I kept the one that came with my old Passat's tool kit, but haven't had a need to use it yet. The disc and hub haven't rotated on me yet when I turn the wheel to line up the holes.
      01-04-2016, 06:10 PM   #8
BitteEinBit
Field Marshall
35
Drives: '21 X5 M50i DHP
What size are our lug nuts?
      01-04-2016, 06:15 PM   #9
Doanster
Doanster's Avatar
627
Our lug bolts are 17mm, 14x1.25, cone seat. Don't have the stock length off the top of my head. Will measure when I swap my stock setup back in a couple weeks.
      01-04-2016, 06:45 PM   #10
BitteEinBit
Field Marshall
35
17mm, ok, thanks! I want to make sure I buy the correct socket.
      01-05-2016, 10:58 AM   #11
stewy604
stewy604's Avatar
290
Yea, not usually a problem. I just find they really help with the rears especially, as they're rather heavy and often awkward to 'get up there.'
      01-05-2016, 01:19 PM   #12
Terp335
116
Drives: E90 2011 335i M Sport
Here is the link to the jack pad adapter I use. I've used a hockey puck in the past as well, but clearly this is better.
http://burgertuning.com/BMW_jack_pad_adapter.html
      01-05-2016, 01:38 PM   #13
Stang0811
Any recommendation on a good car jack to get?
      01-05-2016, 01:59 PM   #14
Terp335
116
Here is a link to one on Harbor Freight which has great equipment. I've had on older model of this one (its a 2.5 ton jack) and its been awesome. Its low enough to get under my 3 series and I've used it for the last 6 seasons to swap tires.
http://www.harborfreight.com/3-ton-l...ump-61253.html
      01-05-2016, 03:13 PM   #15
stewy604
stewy604's Avatar
290
Big vote rapid pump floor jack...not sure how I lived without one.
