06-09-2023, 01:11 PM | #1 |
Rep 218
oil pan gasket and rod bearing replacement (N63)
I have a 2017 x5 N63 with 90k on it. Upper pan gasket is leaking. Figured I'd change the rod bearings while the pan is off. Looks like they don't make ARP rod bolts?? Going to change the motor mounts while its all apart too. Anything else I should be looking at while this is tore down? Sophisticated Redneck maybe you can offer some input?
06-09-2023, 05:20 PM | #3 |
Rep 218
06-09-2023, 07:11 PM | #4 | |
150
Rep 349
Personally, I would send it down the road while it was in good running order. It is my understanding that it is a real crapshoot messing with the bearings on these BMWs. Maybe it's just the N55s I have read about self-inflicted destruction replacing bearings? I dunno. Might be a bigger risk than it seems. |
06-10-2023, 05:25 PM | #5 |
Rep 1,019
06-11-2023, 03:37 PM | #6 |
Rep 218
That's exactly why I wanna replace since I gotta take the upper pan off anyway. Im unsure if what to do now, there's some talk of the tolerances being too tight at .001", ACL sells a larger bearing that gives a .002" clearance. most of my driving is less than 10 minute trips. So a lot of cold starts.
06-11-2023, 11:42 PM | #7 |
Rep 5,002
Tough call, but I get it.
If it were me and the stock clearances made it 90k I’d stick with the stock clearances. Plastigauge each one as you go and send it if they are pretty uniform. On the in-line sixes BMW normally specs .035mm - .055mm clearance. That .001” is about .025mm. BMW factory clearance specs for the n63 b40/44 are between .025 and .070. Wider range than I’d expect. .002” is about .051mm. I normally average the figures and shoot for the middle. So, about .0475mm in this case. Might wanna be two sets of bearings and install accordingly. |
06-12-2023, 12:32 AM | #8 |
Rep 1,019
The STD ACls is all you should need.
The lack of ARP bolts sucks, +BMW confusion on weather or not 3x repeat on the torque steps are needed, does not make the process fun. Current ISTA instruction and talking to mechanics, both agree that you don't need to do the torque sequence 3 times. Just once. I do wonder, if there is a suitable bolt pattern from ARP that we can use in these. I member reading something like the m3 v8's were using the m5 V10's bolts, just trimmed. |
06-12-2023, 01:44 AM | #9 | |
Rep 218
