      03-08-2018, 10:47 AM   #1
03redtypes
Drives: 2011 535i Msport
Bmw -/+ control arm for an alignment
So getting an alignment and they said to make it within Bmw spec I needed to get this. Any info on this? Seems puzzling, but I’m not sure. I just installed a set of KW v3s yesterday.
      03-08-2018, 03:54 PM   #2
yewlock
yewlock's Avatar
Drives: X5
Camber kit?
      03-08-2018, 03:58 PM   #3
03redtypes
Originally Posted by yewlock View Post
Camber kit?
Yeah I’m assuming that’s what they meant it explained a new control arm through Bmw. Was just curious cause I hadn’t heard anything about this on here at all. I got within .2 of where I needed to be on the front so don’t need it like they thought I might.
      03-08-2018, 05:01 PM   #4
Chigger
Drives: 2015 X5
Any other members with KW v3s with this issue? Are you slammed really low?
      03-08-2018, 05:10 PM   #5
03redtypes
I’m honestly probably halfway. So persay I’m about 2.5-3in I gap I’d say. So not all the way down, but not up all the way. I’m debating on going lower, but I’d rather not have to buy something else/ or have it realigned.
      03-08-2018, 10:57 PM   #6
yewlock
yewlock's Avatar
Drives: X5
If you google search, you can see a lot of people have excessive wear on inner tire because they do not install camber kit after lower their car. It is either the toe or camber is way out of spec. This usually happen after 15k-20k miles. Most X5 that run RFT here is about to change their tire around this time.
