      12-27-2019, 03:16 PM   #1
Zuza_Zoomin8
Drives: 2019 440i Xdrive
Question About Sport+ Coding with Bimmercode
Hi guys,
So I'm new to the BMW coding/modifying world and need some quick help in regard to bimmercode on my 2015 X5 35i base line. I have managed to code the Sport Auto Transmission and it definitely works. However, I could not find the options necessary to code sport+ mode, which is needed to use launch control according to my research. I have contacted bimmercode and they say that the option to code sport+ is unavailable on my car, but there definitely is a 2015 X5 m-sport that has the sport+ option as I have test driven one before. Is there any way you guys could help me with this? I'd appreciate it a lot and I'm looking forward to becoming an active bimmerpost member!
      12-27-2019, 04:36 PM   #2
Jason73
Drives: 2022 X3 M40i
You can only code launch control with BimmerCode. Not Sport+.
      12-27-2019, 04:38 PM   #3
Zuza_Zoomin8
I have coded launch control and many others have been able to code sport+ with BimmerCode either through the normal mode or expert mode. I have been unable to find these options though.
      12-27-2019, 04:44 PM   #4
Jason73
Tried several times without success to do Sport+ with BimmerCode. You have to use E-sys to code Sport+. But if you know the trick let me know, I finally gave up after I contacted BimmerCode and they told me the same thing.
      12-27-2019, 04:47 PM   #5
Zuza_Zoomin8
I ordered an enet cable already for a bm3 stage one tune and will try to figure out esys next. I'll definitely let you know if I get it working
      12-27-2019, 04:52 PM   #6
Jason73
BimmerCode is different from E-sys. BimmerCode is an app that uses Bluetooth connection via OBD connection. E-sys is much more advanced. Uses a laptop.
      12-27-2019, 04:55 PM   #7
Zuza_Zoomin8
I know that, I said that I have purchased the enet cable necessary for the bm3 tune and will use it with esys to code my car with a laptop once I have tuned it. I originally thought esys would be too complicated and went with BimmerCode as it is an app and easy to use but have decided that esys is more configurable.
      12-27-2019, 05:08 PM   #8
Jason73
Was not sure you did. You definitely can code Sport+ with E-sys. There is a write up under one of the cheat sheets. But you can not code it with BimmerCode not advanced enough. I believe it is under the “BMW coding” thread.
I do not have the patience to use E-sys
