      07-23-2014, 10:21 AM   #1
NPickles
United Kingdom
71
Drives: F15 40D SE Space Grey/Terra
Coding one touch boot close from fob
Apologies of this has been asked and answered before but is it possible to code one touch boot/trunk closing from the fob? I know closing from the fob is possible to code in the US where it is disabled by default but can it be made one touch?
In the UK it appears that from the fob it is one touch opening but when closing it stops as soon as you let go of the button.
Thanks,
      07-23-2014, 10:26 AM   #2
stewy604
stewy604's Avatar
289
Try this via coding, I believe the keyfob will be single touch, but the inside button will be continuous hold. Perhaps someone else can confirm, as I haven't coded my F15 yet.
Module: Section: Function Value: Default Value: New Value:
HKFM 3010 SCH_FBD nicht_aktiv aktiv
HKFM 3010 SCH_TOEHKI nicht_aktiv aktiv
HKFM 3010 TASTER_FBD nicht_aktiv aktiv
2007 Suzuki GSX-R 750
      07-23-2014, 10:36 AM   #3
Baunton
Baunton's Avatar
England
320
Drives: X5 45e 2021
Its the other way round; inside is one touch both on the door and the tailgate and the fob is hold. My understanding this is for safety reasons so no kiddy winks get trapped between tailgate and chassis if they play with the fob.
      07-23-2014, 10:39 AM   #4
NPickles
United Kingdom
71
Thanks @stewy604, I've just checked mine offline and SCH_TOEHKI & TASTER_FBD are both set to nicht_activ so I'll try enabling them and see what happens.
      07-23-2014, 10:40 AM   #5
stewy604
stewy604's Avatar
289
Really? I could've sworn that my inside button must be held to close the tailgate. If its wasn't raining, I'd walk outside and check it. Haha.
      07-23-2014, 10:41 AM   #6
NPickles
United Kingdom
71
So will those settings work to do what I want?
No kiddywinks so no problem for me
      07-23-2014, 10:56 AM   #7
Baunton
Baunton's Avatar
England
320
Drives: X5 45e 2021
Maybe its different here in England, as soooo many things are
      07-23-2014, 10:59 AM   #8
Baunton
Baunton's Avatar
England
320
Drives: X5 45e 2021
To code one touch boot/trunk closing from the fob?
Pass..sorry not into coding.
Ditto WRT KW's
      07-23-2014, 07:16 PM   #9
NPickles
United Kingdom
71
Having just coded and tested these settings on mine, UK spec F15, I end up with the following.
From the fob, one touch open and one touch close @stewy604
From the button inside on the drivers door it is one touch open and pull up and hold to close as before.
      07-23-2014, 07:55 PM   #10
Here are the coding that you need.
HKFM - 3010 - SCH_FBD from "nicht_aktiv" to "aktiv" - For one touch close from inside button
HKFM - 3010 - SCH_TOEHKI from "nicht_aktiv" to "aktiv" - For one touch close from keyfob
HKFM - 3010 - TASTER_FBD from "nicht_aktiv" to "aktiv" - not sure, but needed to enable the features.
For more, here is the link of the cheat sheet that I've started with the updates from fellow forum members.
https://docs.google.com/spreadsheets...9s4/edit#gid=0
SPRING Sale!! 04/01 - 04/15 - Code: "SPRING2024"
      07-23-2014, 09:10 PM   #11
NPickles
United Kingdom
71
On mine, UK Spec, SCH_FDB was already set to Active and it didn't one touch close from the drivers side button either before or after coding the other changes
      07-23-2014, 09:14 PM   #12
hmm.. that's weird. I know that in the US by default you can close from the button by pulling it up and holding it.
With the coding, you just press it down as when you opening the tailgate and it will close with 1 press. So, 1 press it will open it, and press it again and it will close it automatically.
If that doesn't work, maybe there are some other thing that need to be coded.
      07-24-2014, 03:37 AM   #13
NPickles
United Kingdom
71
My mistake, I was pulling it to close, not pushing it again. It takes a second or so to kick in and close from the button on the drivers side but it works now pressing one touch to open and pressing one touch to close, once it has started moving.
      07-24-2014, 05:04 PM   #14
ramsal
Drives: 2017 X5 & 2018 M3
You are correct Stewy604, mine behaves the same way.
Search this Thread:
Advanced Search
