07-14-2014, 01:19 PM | #24 | |
Rep 1,368
07-20-2014, 08:30 PM | #25 |
Rep 19
I saw e92 forum enable rear foglight and DIY rear foglight switch. Cut the trim to enable the rfl. But to put back the switch so hard. I didn't remove the dash cover air condition it lucky pop out. But it didn't work as E92. Anyone did it ? I need help how to remove dash AC above light switch for put the light back ?
07-22-2014, 12:55 PM | #26 |
Rep 406
Drives: X5 35I
I like your garage. Nice and clean.
07-23-2014, 08:18 AM | #27 | |
Rep 926
However, Audis and MBs still offer rear fogs in the US
92 Mazda Mx6 (sold), 00 VW Jetta (sold),
07 BMW 335i (sold), 10 VW Jetta (sold), 14 BMW X5 35ix (sold), 18 VW Jetta (totaled), 19 Audi SQ5 (sold), 20 Audi S6 (sold), 22 Audi SQ5 |
07-15-2015, 06:51 PM | #28 |
Rep 3,834
Do you guys know where I can find the UK spec rear fog light button? I removed the button on my F85, it's not like the F30/F80/F82/F83 where I could just trim off the stopper (see thread below). The button that came with the F85 in the U.S. is a dead button and cannot be modded. The circuit board is the same as the UK, I just need the button from an F15 from UK. The car is coded and ready.
http://f80.bimmerpost.com/forums/sho....php?t=1023817
07-16-2015, 12:07 PM | #29 |
Rep 431
07-16-2015, 05:13 PM | #30 |
Rep 1,744
We had rear fog light (not lights, mind you) on our ML350..
Only the driver side had fog light, that was even more annoying than having two. I would see other ML drivers with only one bulb and my OCD nerves would just make me cringe. So, if there is anything worse than having two rear foglights blind you in clear night is a single one on the driver side blind you. In USA I don't mind not having rear fog lights, but what bothers me most is not having rear DRL's. That should be standard with all new vehicles.
07-17-2015, 12:00 AM | #32 |
Rep 11,136
07-17-2015, 07:17 AM | #33 |
Herr Oberst
244
Rep 531
07-17-2015, 04:07 PM | #34 |
Rep 1,886
To enable fog in rear in U.S., you'll need a new switch and coding. And, you will disable "Brake Force Display" (see manual) as it uses the same LED section. That is minimum. You may also need a a new wiring harness as there is different harness for Euro lights. Odds d the wiring needs are low, is my guess.
