06-11-2014, 05:50 PM | #1 |
Rep 4,106
f15 35i tune group buy
Many of you pm'd me to contact the group buy administrator and get group buy pricing for 35i's as well.
Here you go: http://dtmhaus.net/bmwx5fxdracr.html Use code racechips
Current: 21 M5 Comp, 17 X5M, 06 M3, 14 Ferrari FF, Tesla Model S Performance.
06-11-2014, 06:46 PM | #2 |
Rep 67
Does this chip work on top of M Performance Power Kit?
I had my MPPK installed and wonder if there is conflict if the RaceChip is added on top of it. |
06-11-2014, 08:39 PM | #3 | |
Rep 18,713
Because the way those tuning chip work is just tricking the reading of the sensors and inputing a wrong information to the ECU which causing the ECU to tell the engine to push more power. So, in your case, I do believe it will push more power, but it will be basing the base number on the gain that you have from the MPPK. With that, you most likely pushing the engine beyond the safe limit of the engine itself. Unless, with those combo, you are doing more mods to the engine, such as, upgraded fuel injector, fuel pump, intercooler, turbo, etc.
06-11-2014, 10:14 PM | #4 |
Rep 4,106
Luckily our engines are equipped with enough safety precautions to throw a CEL and pull timing if anything is sensed to be out of ordinary. Unlike many others piggybacks this one not only uses boost sensors but also air/fuel sensor and Maf sensor. The ecu is not as restrictive as f10 m5 ones and you can actually have semi control over it with the option to control your hp and tq increases individually.
06-12-2014, 07:55 AM | #6 | |
Rep 20
2014 X5 XDrive 35i
06-12-2014, 08:04 AM | #7 |
Rep 20
OK found the video on adjusting the chip, now to find about adjusting the 'initial' setting to maybe 15% or 20% boost.
http://http://www.racechip.com/suppo...e/common-rail/
2014 X5 XDrive 35i
06-12-2014, 06:23 PM | #8 |
Rep 609
I must say guys, I dropped off my X5 off Monday afternoon and took my RaceChip out because I was having warranty work done, and what a difference it makes when the unit is removed from the motor. I plugged it in today and drive it around with the new 599 wheels and bot does it give it a nice boost! Loving the 599's, they really give it a new look! Back to the RaceChip, it's worth every penny, just do it. You'll be glad you spent the money! The plus is it takes 4-5mins to install and remove.
Joe |
06-12-2014, 07:48 PM | #9 | |
Rep 67
Is there any boost controller to be installed in the center console in order to change the boost level on the fly? Ray |
06-12-2014, 07:55 PM | #10 |
Rep 609
Hi Ray, no there isn't any. I have it set at E/2 and have zero issues with boost or power. Zero CEL's and I must say it gives it the power it deserves.
06-12-2014, 07:56 PM | #11 | ||
Rep 67
That's exactly what I'm worrying about... 300+20+89 hp = 409hp That just seems too much for a 3.0T SUV...but I really wonder how it pushes to its limit. Thanks for the info! Ray |
06-12-2014, 08:03 PM | #12 |
Rep 67
@mikikuki7
Yes, there is one for 50i. Same price, but only 14%HP boost from 443 to 507hp. https://www.racechip-usa.com/chiptuning/BMW/X5/X5-(F15)/xDrive-50i-330kw/ |
06-12-2014, 10:11 PM | #13 |
Rep 4,106
You control how much power you want to add with the settings on the tune.
06-12-2014, 10:12 PM | #14 |
Rep 4,106
You guys realize that same motors and transmission with tunes push 600-700 hp in 335's
06-12-2014, 11:56 PM | #16 | |
Rep 18,713
With all this talks about RaceChip, it makes me wonder about those guys that were having discussion with me regarding modding my truck with BMS JB4, Brembo, etc. Also, now it makes me wonder the difference between BMS JB4 and RaceChip.
06-17-2014, 04:15 PM | #17 | |
Rep 4,106
OEM injectors are at 71% of their capacity and even with the slight boost increase the car does not show any lean curves on a air/fuel ratio. Have you datalogged your car? I suggest doing so and you will feel much safer. If you need help with dyno/datalogging and reading graphs let me know. All the F series cars have been dyno proven to have excellent airflow without the possibility for improvement. You would need extra injectors if you run a lot more boost, upgrade turbos, run standalone ecu or some other extreme form of tuning, but not at our stage.
06-24-2014, 09:00 AM | #20 |
Rep 8
Has anyone actually installed and been using the Racechip? I'm considering ordering this for my F15 35i, but wanted to get some real world feedback from a few users before making the leap.
Thanks in advance |
06-24-2014, 03:53 PM | #21 |
Rep 4,106
I tried to get couple of my friends to join the forum and post, but they refuse to join public forums. They have used the tune and love what the car became after.
06-27-2014, 11:11 PM | #22 |
Rep 3,990
Has anyone done the RaceChip tune on the 5.0i? https://www.racechip-usa.com/chiptun...ive-50i-330kw/
I'm considering it, but my cousin told me that BMW has a tool that tells them every time the engine settings are modified with a tune. If this is truly plug and play...is it really factory stock when you take it in for service? I know many of you guys have gone in for service without issue, but what about those guys that have had actual engine issues? Have you guys had any warranty problems or red flags? I remember reading a post where some guy from the MB forums screwed up his car and voided his warranty, but a few members said it was user error. I just want to be safe before taking a plunge into this RaceChip. I know many are very happy and I want to join in. Any feedback is appreciated. I'm still deciding between this or holding off until Dinan (that has 4 year 50K warranty approved by BMW). Thank you .
