      12-14-2023, 07:59 AM   #1
bigshooter
bigshooter's Avatar
Drives: 2014 328d xDrive
2015 X5 5.0i - Drivetrain Malfunction - Misfires in Cyl 6 & 8
I was driving down the highway just cruising the other day and all of the sudden it started shaking. I got home a couple minutes later and scanned it with ISTA.
Misfire cyl 6 & 8
Damaging exhaust gases
I changed the spark plugs and ignition coils but still getting the same error. Given that I swapped all 8 plugs and coils, and the error still resides on 6 & 8, I can’t imagine that switching coils or plugs would change anything.
From my reading on here it sounds like injectors is the next thing to looks at. If I had a bad MAF, I would think the whole bank would be misfiring.
Can someone share a link to some instructions or a video on how to run the injector and hpfp tests in ISTA?
I’m about 4k miles over the extended warranty. 124k miles. But since I bought it at the dealership I’m hoping they would goodwill the injector replacement. I would just like to confirm it’s a warranties part before limping the thing down to the dealership.
      12-16-2023, 01:04 PM   #2
bigshooter
bigshooter's Avatar
No one?
      12-17-2023, 09:30 PM   #3
rosscmcd
Drives: F15 50i
Mine did the same about a month ago. Dealer replaced turbo inlet hoses spark plugs and coils and it fixed it. Good luck
      12-19-2023, 07:33 PM   #4
bigshooter
bigshooter's Avatar
I think it’s covered by warranty so I dropped her off today. If it’s not, I’ll be replacing injectors myself
I also should mention I have an auxiliary coolant pump short circuit error as well. It’s a little plastic coolant pump for the turbo I believe.
      01-16-2024, 12:17 PM   #5
jfandl
Drives: 2014 BMW X5 5.0 (F15) - BM3
Did you find out what the problem was? bigshooter
      02-05-2024, 05:29 PM   #6
bigshooter
bigshooter's Avatar
No compression cylinder 8. Car ran perfect is well maintained. Happened out the blue. Quote was $27,000
      02-05-2024, 09:21 PM   #7
stocktree
Drives: x5
Is warranty covering it?
      02-06-2024, 01:52 PM   #8
Djhumvee
Drives: 2017 X5 50i
How does a cylinder all of the sudden lose compression?
