      12-21-2021, 05:46 PM   #1
M3HNGRY
Drives: '18 AW X5 35d Msport
Rear Air Suspension Level Sensor
How sensitive are these Sensors?
Part # 37146870200
When I was installing my Dinan Links. I was playing around with the sensor (Driver Sensor) and spun it around and around.... Now the driver side rear sags/deflates overnight. Did I just ruin this one sensor or just happen that my driver airbag took a dump?
2018 with 56k miles.
      12-21-2021, 07:51 PM   #2
Akkord29
Drives: F80, G20, E46
Try putting the original link back in or switch the sensor from the passenger side.
I changed one out recently and was around $100 from the dealer.
      12-22-2021, 05:53 PM   #3
M3HNGRY
What symptoms did you have to warrant a replacement? TIA
      12-22-2021, 08:03 PM   #4
Akkord29
Installer error...power tools were probably too much for it
      12-23-2021, 12:59 AM   #5
M3HNGRY
Debating to buy a new one to see if it solve my problem. This happen right after I install the links. No issues with air bags leaking or dropping over night...
      12-23-2021, 08:54 PM   #6
Akkord29
I would try switching the left and right sensors to see it if still drops first.
      12-30-2021, 01:42 PM   #7
M3HNGRY
New sensor came in and installed. Hopefully, it resolve me issue.
      12-31-2021, 11:14 AM   #8
M3HNGRY
Yaya new sensor solved me problem. So tip for anyone who wonder why car is lowering overnight but airbags and valves are in great shape. Sensor are sensitive to position and can't spin arm around and around.
      01-03-2022, 02:08 AM   #9
Akkord29
Sucks that playing with sensor did it but happy the sag is gone.
      07-04-2023, 10:41 AM   #10
Giord78
Drives: 2017 BMW X5d
Level Sensor, Airspring or other??
Thanks for all the great info here. Trying to diagnose my issue, which is similar. Drivers side goes down sporadically, pumps up and may be fine for days or weeks. Recently it went down several times over a 24 hour period, but has now stayed up w/ no issue. I used my iCarSoft to track the sensors ride hide deviation. So far they are staying the same. I was going to change the airspring, but now I’m considering starting with the sensor. Any thoughts appreciated.
John
      08-23-2023, 04:24 PM   #11
hamh
hamh's Avatar
85
Drives: X5 MSport + VW GTI
did you guys get the genuine bmw part for this sensor or aftermarket will do?
