05-11-2023, 07:27 PM | #23 |
Rep 480
05-13-2023, 03:40 AM | #24 |
Rep 219
I think I paid around 2200 or 2500, and it came with pads, just have to buy rotors. bigger calipers than the m brakes although the diameter of the rotors is smaller. He posts on here quite often you just gotta search the forum, there's so threads From him about selling the calipers, he's the same guy that made the upgraded driveshaft which is a more recent topic. I think they're 4 piston rears and 6 piston fronts if I remember correctly.
05-14-2023, 02:15 AM | #27 | |
Rep 5,002
Didn’t know about the AC condensation drain. Good lord, thanks BMW. |
06-30-2023, 08:50 AM | #28 |
Rep 480
Just an update…car has been perfectly smooth since I changed the fluid and recalibrated the transfer case. 99% sure the issue was caused by the previous owner changing only the rear tires and then changing the fronts 4k miles later. They did that a couple thousand miles before trading in the car…guess they noticed the issue, too 😂
_ObiJon200.00 |
08-29-2023, 05:47 PM | #29 |
Rep 299
Just to further validate everyone's recommendations to change the transfer case fluid and reset the adaptations, i just did the service myself over this past weekend. I used ProTool to initiate the TC calibration, as i already had it to code a brake upgrade on my F32. Not only did it rectify the unfavorable driving conditions mentioned in this thread but it also cured a shutter/shimmy i had on decel from ~30 to 20 mph. Completely smooth now - like a brand new car. Old fluid was pitch black.
I started a separate thread on front driveshaft play. While the car rides smooth now, it's still on my list to swap out as I'm not completely comfortable with it. Thank you everyone! |
tfunk88192.00 |
08-29-2023, 06:53 PM | #30 | |
150
Rep 349
Now, don't screw up your good luck and put off the driveshaft replacement. Get on it. lol |
08-29-2023, 10:58 PM | #31 |
Rep 459
I will have upgraded driveshafts finally available starting next week, i will make a separate post on this, just a heads up though |
4
